Ford Trans ?? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old January 18th, 2007, 01:04 PM   #1
74_jeep
74_jeep's Avatar
Default Ford Trans ??
Anyone ever have a transmiision go in Ford windstar .??
1998 windstar with a 3.8 , going down the road fine .Then all of a sudden , no forward motion . Coasted over to a lot , no reverse , drive , 1 or 2 just gone.
Fluid looks normal , changed the transmission range sensor ( neutral switch ) . still nothing .
Just wondering if there are some solutions , before hitting a trans shop .
Heard there are some problems with this and the probe transmission .
74_jeep is offline   Reply With Quote
Old January 18th, 2007, 01:28 PM   #2
Bones
Bones's Avatar
no noiese or anything from the trans? Does it feel like things are binding?
Inviscid Motorsports
Motorcity Machines
Branik Motorsports
Maxxis Tires
Raceline Wheels
PAC Racing Springs
Joint Clutch and Gear
Old January 18th, 2007, 04:39 PM   #3
74_jeep
74_jeep's Avatar
No noises , no binding . Took off from the light and all of sudden nothing .
Engine runs fine , no lights on the dash or the end of the lever. Supposed to flash on the end of the selector lever if a trans code is present.
Old March 28th, 2007, 05:14 AM   #4
ricdawg
ricdawg's Avatar
Sounds like you maybe broke the shaft off between the torque converter and pump. Need to put a gauge on it to see if you have pump pressure. Not familiar enough with that particular type of trans to tell you where the test port is.
Rick
ricdawg is offline   Reply With Quote
Old March 28th, 2007, 07:46 AM   #5
Tom
Because racecar
Tom's Avatar
That trans has a problem with the pump shafts wearing out on them, and as a result they leak pressure. also the servo pin can break resulting in a no forward movement, but yours doesn't back up either. Is the fluid high on the dipstick? If it is, the pump went bad. It also could be a t.converter because ford had problems with those from 95 to 99.
Page generated in 0.17511 seconds with 38 queries
