Big block 4x4 just aint right - Great Lakes 4x4. The largest offroad forum in the Midwest
Old January 17th, 2007, 09:22 PM   #1
Gr8wht2000GMC
Gr8wht2000GMC's Avatar
Unhappy Big block 4x4 just aint right
riddle me this.....2000 GMC K2500 Crew w/7.4L Every time the truck is started...hot or cold....NO ASS for 25 to 30 seconds.Runs weak, coughs thru intake, codes PO171 and PO174(lean rt+lft). Then all of a sudden runs awesome for ever unless i shut it off. new pump installed last Sun. New O2's installed, new plugs-wires-rotor, new fuel filter, new air filter. local "expert" says bad maf and/or temp switch but im really tired of throwing $$$$$ into a problem that three reputable mechs cant seem to diag. Even Mr Goodratchet himself baffled Any similiar probs or more ideas would be great
Gr8wht2000GMC is offline   Reply With Quote
Old January 17th, 2007, 09:58 PM   #2
Yetti
Buy a Fiat! Save the UAW!
Yetti's Avatar
The best Idea I have involves beer and a old buddy of mine who is a Chevy expert. I too can only guess on this system. one of the things that comes to mind is your ECM maybe having issues with the open loop function. its got 3 minutes to get the engine warm and after that it goes to closed loop to meet emissions. I am wondering if you have a bad injector or TBI Gasket is sucking air on one side real bad making a lean condition until the computor makes it to closed loop. its just odd. I did have one years ago that had a cracked intake and was sucking air under the tbi through the crack that went from one side to the other..
Yetti
Old January 17th, 2007, 10:06 PM   #3
mrbotie
recovery man
im not saying i know the problem with ur truck but the same engine and truck combo same problem but it was not every time maybe every other it had to do with the computer its just an idea
mrbotie is offline   Reply With Quote
Old January 17th, 2007, 10:09 PM   #4
Gr8wht2000GMC
im leaning to the pcm myself... maybe ought to just drink beer and think some more.
Old January 17th, 2007, 11:54 PM   #5
KILLER"B"468
Yankabilly
KILLER"B"468's Avatar
They had intake gasket leaks. Have you tried snugging up the intake bolts.
Old January 18th, 2007, 11:09 AM   #6
nmeinc
Parts Galore Spokesmodel
nmeinc's Avatar
did you reset to computer after you replaced stuff? sometimes it will hold onto a setting even if the part has been replaced.
nmeinc is offline   Reply With Quote
Old January 18th, 2007, 01:32 PM   #7
Bones
Bones's Avatar
actually the temp senser might be a really good guess
Anyone with a scanner/reader should be able to read PID data. Monitor the intake air temp, coolant temp and any other temp sensors maybe oil) to see if any of them are unusual for the first few minutes of start-up.
Inviscid Motorsports
Motorcity Machines
Branik Motorsports
Maxxis Tires
Raceline Wheels
PAC Racing Springs
Joint Clutch and Gear
Old January 18th, 2007, 01:39 PM   #8
Mud'N'Truck
I'll Finsh One, One Day
Mud'N'Truck's Avatar
After you install new sensors or thing of that nature the computer has to go though a few drive cycles. You can't just jump in and feel a differnce. So after replacing things drive it for a while (not just to the corner and back). If the problem is still there move on to your next idea. I also think you need to have it plugged in and see what the scanner says.
Old January 18th, 2007, 05:33 PM   #9
Yetti
Yetti's Avatar
I need more info. I went to pick some brains at the dealer I worked at and everyone was baffled. it seems something is missing in our info stream. It might help to know everything that has been done to and with this truck and if its been in a wreck or anything like that.
Yetti
Old January 19th, 2007, 03:54 PM   #10
Gr8wht2000GMC
thanks for all the ideas...well Yetti, never wrecked. Icant even remember exactly when it began. the local "expert" I refered to owns a respected mech shop. i took it over to him yesterday and he scanned with a snap-on diagnostic tool. everything looks cool....except MAF readings a little off. EVERYBODY seems baffled its really like the thing wont run in open loop. its a dd and ocasional offroad. it has tru dual ex. all the new parts listed +fuel pressure reg. NEW intake gaskets and computer reset after work requiring it to be. going to get temp switch now.....add more l8r
Old January 19th, 2007, 04:07 PM   #11
ScOoTeR
hoo dat. wat.
ScOoTeR's Avatar
You have a massive airleak or fuel restriction somewhere. You're running wayyyyyyy lean in open loop - coughing and popping are a good sign of that, also the lean codes are from the ECU having to compensate for the lean condition.
@clarkstoncracker
Old January 19th, 2007, 04:19 PM   #12
Gr8wht2000GMC
fuel pressure is constant at 62psi, static test and running thru rpm range. fuel volume is really good as well. what i cant understand is how it cleans up so suddenly and runs like a awesome beast until i start it the next time. what about a stuck EGR????? could it be dumping in exhaust gas during those fisrt 23-30 sec?
Old January 19th, 2007, 05:19 PM   #13
Originally Posted by Yetti View Post
I too can only guess on this system. one of the things that comes to mind is your ECM maybe having issues with the open loop function. I am wondering if you have a bad injector or TBI Gasket is sucking air on one side real bad making a lean condition until the computor makes it to closed loop...
I'd try hunting this down.
Open loop is generally during start up, and heavy throttle up around 70% and higher.
So, at stat up/idle, it'll run like ass.
In closed loop, it'll compensate for it pretty well.
In wide open throttle, you might be running lean and not knowing it. In fact, you might be happy getting more power and/or better mileage. Factory calibrations are generally based on SAFE operating conditions. There's almost always power/mileage to get had by leaning a motor out, at the risk of detonation, etc.
Old January 19th, 2007, 05:43 PM   #14
Gr8wht2000GMC
aside from near death experiences while initially entering traffic.................I am pleased with the 12 to 13.5 mpg Ive been getting. Actually starts and idles smooth as glass. if i had to describe exact symptoms id say...its like the feul lines are all fulled up and as i apply throttle, i consume the fuel and have to wait for the pump to "catch up"..but all fuel tests are cool. I would agree with massive unmeasured air causing lean...but can pcm really correct that much? and ...in order to compensate shouldnt i see poor economy...HA thats funny using the word economy in a post about a 454...anyway if all i wanted was economy id buy a toyota. just really frustrated not like the good ol days of carbs
Old January 19th, 2007, 05:46 PM   #15
Gr8wht2000GMC
agree 100% but wouldnt a MASSIVE air leak be pretty obvious? gonna geta barley pop and think some more
Old January 19th, 2007, 09:15 PM   #16
Get out some carb cleaner with a straw on it, and start spraying it around anywhere that might have a gasket leak.
I think its carb cleaner.... or maybe it was starting fluid. Or that might go boom..
No, I doubt you'd necessarily notice it. Its just like having a carb leak at the base, its not always obvious.
Old January 20th, 2007, 05:49 PM   #17
Yetti
Yetti's Avatar
yea I still stumped. I have run every senario I know I can't come up with a reasonable explanation. If had to chose another route to explore I would look at the exhaust side of things. and yes to answer your questio the EGR could mess it up by being open when its not supposed to be. the other thing to consider would be a blockage at the catylitc converter that is opened by heat. it could be the opening to the monolite converter are collapsing and blocking the exhaust enough that it runs like shit cold. I would drop the exhaust pipe off to the end of the manifold bolts and test run it. if it runs right cold I would remove the curent converter and try again with a test pipe or replacement convertor.
ps, I had the worst TBI 454 ever. it was bone stock and got a 3.5 mpg
Yetti
Old January 20th, 2007, 06:09 PM   #18
Out of curiousity, have you tried unplugging the O2 sensor and starting it with it unplugged?
I'm curious, with no O2 it can't go into closed loop. If its an open loop/closed loop issue, then it'd continue to run crappy even after the 30 seconds.
Any results from checking for air leaks?
Old January 21st, 2007, 07:45 PM   #19
Gr8wht2000GMC
i wil definately try removing exhaust as this has crossed my mind as well...i will also try the o2's unplugged even tho they are only a week old...no luck with spraying carb cleaner around intake....i tore the whole top plenum off today and replaced upper gaskets.. no evidence of any intake leaks top or bottom...replaced a suspect vac line from egr to purge canister . in fact if i remove the air filter and put my hand over the tube it tries to pull my fat ass in and the truck dies instantly so i cant see any excess unmeasured air contributing to this prob. the only other thing i havent explored yet is the fuel rail and injectors. but i dont know what to even suspect on an injector, much less 8 of the things.
Page generated in 0.43430 seconds with 80 queries
