XJ Oil pumps - Great Lakes 4x4. The largest offroad forum in the Midwest
Old January 11th, 2006, 11:39 PM   #1
xjmichigan
xjmichigan's Avatar
Default XJ Oil pumps
im looking to boost my oil pressure back to closer to normal ranges--
cold idle pressure 40+
after a 30 min hiway drive coming to a stop at idle pressure drops to 0 (and can hear engine starving for oil)
rev engine up to 2K pressure is at 20
i thinking my current pump has some wear with currently 140K miles or it could be the pressure relief spring in the pump that is worn out
as a last resort i was thinking about replacing the crank bearings
would a i need a high pressure pump OR hi volume pump?
Old January 12th, 2006, 02:58 AM   #2
Yetti
Buy a Fiat! Save the UAW!
Yetti's Avatar
if you want to improve what you got without a rebuild then go with the High Volume pump. it will make up for wear & tear.by the way have checked the sender? it could be bad and giving you a false reading just my .02
Yetti
Old January 14th, 2006, 11:58 AM   #3
CHVYPWR
D.I.L.L.I.G.A.F.
CHVYPWR's Avatar
Not using a Fram filter are you? 4.0's don't like the restrictive Frams.
Old January 14th, 2006, 12:52 PM   #4
PavementPounder
PavementPounder's Avatar
I think that posting this in Jeep Tech would help your oil pressure a lot.:tonka:
Not to mention get your post more replies.
Old January 14th, 2006, 07:49 PM   #5
Monkeyevil
I <3 Miatas
Monkeyevil's Avatar
High flow pump is a bandaid to the real problem... and IMHO a waste of money.
When my Jeeps bearings were going it would do the same thing... 50 on startup, and 0 at warm idle. I milked it with some motor honey for a few months until it started burning a quart every 300 miles. Then a did a motor swap.
JcrOffroad
Zoom Zoom!
Page generated in 0.18289 seconds with 38 queries
