wtb: small starter - Great Lakes 4x4. The largest offroad forum in the Midwest
Old January 11th, 2006, 04:28 PM   #1
BooGTS
Boost Withdrawl
BooGTS's Avatar
Default wtb: small starter - found
I'm looking for something that can turn at least 500rpm with 50 in lb of force that is small and light for turning over a high compression weedwacker engine. Thanks!
BooGTS is offline
Old January 11th, 2006, 05:07 PM   #2
clarkstoncracker
lol
clarkstoncracker's Avatar
Need more information.
Is this engine staying in the weed wacker, or is mounted to something else?
clarkstoncracker is offline
Old January 11th, 2006, 05:35 PM   #3
BigBlkYJ 355
U-Joints Fear Me
BigBlkYJ 355's Avatar
might want to look into the gas powered radio control industry. the 1/4 scale stuff uses 31 cc gas engines. i know some of them use electric start.
BigBlkYJ 355 is offline
Old January 11th, 2006, 09:37 PM   #4
BooGTS
Boost Withdrawl
BooGTS's Avatar
I thought that before I posted, but figured they wouldnt be powerful enough. I did find something though. It cost $130 for the starter, but then I noticed they had a part listing. $45 for just the motor - score! Its the biggest thing they offer and I think it will fit out needs nicely. It provides 37in/lbs (I was exxagerating on the 50 part - we absolutely needed 35) at enough RPM to get some more mechanical advantage out of it just for more breathing room.
I called them up (tower hobbies), and gave me the weight (its for a supermilage car) and even a dyno sheet. We saved over 15lbs from our previous starter. Its a Sullivan Stage 4 motor if that means anything to anyone.
BooGTS is offline
Old January 11th, 2006, 09:44 PM   #5
BigBlkYJ 355
U-Joints Fear Me
whats is being used for?
Old January 13th, 2006, 12:16 AM   #6
BooGTS
Boost Withdrawl
BooGTS's Avatar
Like I said in my above post - a supermilage car. Last year we got 700mpg with a blown headgasket, so dropping 15lbs and having a good HG (hopefully) we should be much improved.
BooGTS is offline
Page generated in 0.28869 seconds with 41 queries
