4.0L no start - Great Lakes 4x4. The largest offroad forum in the Midwest
Old January 14th, 2007, 11:59 AM   #1
Default 4.0L no start
helping a buddy out with this
we have a 90 ranger with 2.9L 5spd
had a 91 explorer 4.0L Auto
i took the 4.0L and all components (pcm, wiring harness, everything from behind the dash etc..)
and swapped it in the ranger
i bypassed the neutral safety to get it to crank
cranks just fine.....but i have no spark, and no inj pulse.....i have gone back over everygrd and pigtail and have found nothing wrong....
i have battery voltage at injectors and 1.5 volts at crank sensor, i ohmed crank sensor and compared to a known good one (same reading)
checked all three relays and they work...checked for voltage at ICM and Grd, both were present....don't know where else to go
all i have is a crappy haynes manual...if i was at qork i would have alldata and could probably figure this out but i don't so i need help
Old January 14th, 2007, 12:34 PM   #2
tried a known good ecm and icm, still nothing, now i am official stumped
Old January 17th, 2007, 05:17 PM   #3
larboc
Pirate of Dollar Bay.1TBB
Just a couple thoughts, possibley some kind of anti-theft system? have you tried using the orignial key tumbler?
Does the fuel pump prime the system at key on? possibley try jumpering the oil presure sending unit wire?
I'd check that crank sensor agian as well. perhaps whatever triggers it isn't there anymore?
If not, I'd guess its something simple, wires not connected, etc.
Or get a carb!
larboc is offline   Reply With Quote
Old January 17th, 2007, 08:44 PM   #4
ScOoTeR
hoo dat. wat.
ScOoTeR's Avatar
I'm not sure about the CPS on that year, but sensors usually have a 5V supply.
@clarkstoncracker
Old January 17th, 2007, 08:52 PM   #5
i think i have missed a ground or have a bad ground...........i have voltage on the injs and PCM and ICM but no ground.......i have been waiting for work to get AllData back up and runing so i can get some good schematics and ground locations.......just haven't had time the last few days to look at it
Old January 17th, 2007, 08:53 PM   #6
BMFmike
meh.
BMFmike's Avatar
Originally Posted by larboc View Post
Or get a carb!
bwaaaaaaahahhahahhahahahha
classic larboc.
Old January 17th, 2007, 11:00 PM   #7
chris1044
chris1044's Avatar
That was my thought as well - the CPS should be a hall-effect type, but I'm not sure of the signal voltage either
Page generated in 0.17470 seconds with 44 queries
