Currie 9"?? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old January 13th, 2007, 08:29 PM   #1
C.K.
Dont Feed the Cyco
C.K.'s Avatar
Default Currie 9"??
Need your opinions.
So I was flipping through a magazine and came across an ad for a Currie front TJ High-Pinion 9". The Currie axle has 31 spline shafts and a Detroit locker, and gears of choice. I was considering swapping a stronger front axle into my TJ. The knuckles on D30 are done. I will be running a 39 - 42 inch tire. I have a bare D44 out of a Rubi that I could build up and put in it.
I have 2 questions.
1. Am I wasting my money buying a complete axle (about $2900), as opposed to starting with a bare housing and needing to buy everthing to build it?
2. Is the 9 overkill / how does it compare to a D60 or other frontends?
Thanks for any input.
C.K. is offline   Reply With Quote
Old January 13th, 2007, 08:40 PM   #2
Roadhouse
DrivewayJeeper
Roadhouse's Avatar
I only knew one person who ran a Currie hi pinion 9", with 37's. He didn't have good luck with it...broke constantly.
They might have improved them since then, not sure. At the time I just didn't think it was worth the money.
Old January 13th, 2007, 08:51 PM   #3
Plato2k5
In Da Faaaaaace!!!
Plato2k5's Avatar
i think the hp 9" would kick ass!
Old January 13th, 2007, 09:53 PM   #4
silverxj
Recovering XJ owner
silverxj's Avatar
I've known multiple people with a Currie 9" and it's a stout axle, but if you're going to put money into an axle .... ***cough*** rock jock ... ***cough*** iron ... ***cough*** big ... add 1ton knuckles and 40 spline shafts you'll be fine w/ 42".
Old January 13th, 2007, 09:55 PM   #5
cornfed
I have an avatar. Yippee.
cornfed's Avatar
IIRC, the Currie TJ 9" uses or reuses your stock D30 knuckles and outer bits.
Building a Rubicon D44 for 39-42s will be a waste of money. No matter what you do, your ring gear and u-joints will be your limiting factors (this assumes you're up-sizing your bolt pattern).
If you're hell bent on running 39-42s, check out the "609". 9" housing with Dana 60 outers. I'm a bit curious to know why you plan to run a 39-42 and don't have a solid plan for your axle(s).
Old January 13th, 2007, 10:16 PM   #6
C.K.
Dont Feed the Cyco
C.K.'s Avatar
Correct That was one drawback
If I'm a bit curious to know why you plan to run a 39-42 and don't have a solid plan for your axle(s).
Well I have been running 38.5 x14.5 Swampers for the last year on a D30. Now that the down time is here I need to do something about the bent front axle. I ran it until now because it worked. I dont think it will last another year with the shape it is in. If it wasnt bent I would still run the D30 for another year.
Just wanted some opinions from people that have a little more experience than I do before I just go spend a bunch of money on an axle.
Old January 13th, 2007, 10:46 PM   #7
Jeeperz Creeperz
GL 4x4 Vendors
Jeeperz Creeperz's Avatar
The Currie HP 9" is not a 9" gear set so it's not really a 9" anyway...
Old January 13th, 2007, 10:56 PM   #8
C.K.
Dont Feed the Cyco
C.K.'s Avatar
Old January 14th, 2007, 03:27 AM   #9
Rocky
AAA GOLD ROCKS!!!!!
Rocky's Avatar
Ever looked into a Dynatrac 44 or 60?
Old January 14th, 2007, 06:45 AM   #10
C.K.
Dont Feed the Cyco
C.K.'s Avatar
I'm going to do that today.
Old January 14th, 2007, 07:42 AM   #11
silverxj
Recovering XJ owner
silverxj's Avatar
X2 - it's actually an 8.8 r&p ... unless http://www.truehi9.com/
There's a ton of options out there, most depending on preference and money, but I agree, if you're going to put up the coin and build that front axle, look into different outers. http://www.teraflx.com/pages/product_results.php I've seen what a 39"-42" tire will do to rubicon d44 outers, which are basically the same as a d30.
Old January 14th, 2007, 08:46 AM   #12
yogi
swampstomper & old fart
yogi's Avatar
spend your money on the d-60
yogi is offline   Reply With Quote
Old January 14th, 2007, 10:39 AM   #13
Jeepaholic
Axle Guru Extraordinaire
Jeepaholic's Avatar
heard alot of good reviews for these guys http://www.diamondaxle.com/index.htm
Get something with 60 outers for tires that big!
Old January 14th, 2007, 10:42 AM   #14
Blackjackbender
I would say go 60 and dont look bcak? why not just go fullwidth?
Old January 14th, 2007, 10:48 AM   #15
yogi
yogi's Avatar
looks beefy but wonder if they make them up for jeeps
Old January 14th, 2007, 11:10 AM   #16
C.K.
Dont Feed the Cyco
C.K.'s Avatar
Originally Posted by Blackjackbender View Post
I why not just go fullwidth?
I would like to go a few inches wider, but dont want to be too crazy with the width. I do like some of the tight trails we do now.
As is I sit wider than most Wranglers. It is about 82"-84" wide. I just fit on my trailer and I moved the fenders out an inch or so.
Old January 15th, 2007, 11:24 PM   #17
Blackjackbender
running a h2 rim to suck it back quite a bit is always an option.
Old January 16th, 2007, 02:19 AM   #18
hosejockey4506
Visiting Admin
hosejockey4506's Avatar
with full width chevy 60 and a 14 bolt my jeep was 82 inches wide with H2's and 39.5 iroks
Old January 16th, 2007, 08:41 AM   #19
Sure, you can get the 9" center with Dana 60 outers for $1250 for the housing.
Brian is a good guy and does very good work. I have some of his parts on my truck.
Old January 16th, 2007, 09:33 AM   #20
jeepcj75
jeepcj75's Avatar
x2, with 42" tires there really isnt another option.
if you really wanna spend some money, get the hi9 center section with 35 spline shafts and 60 outers
jeepcj75 is offline   Reply With Quote
Page generated in 0.35282 seconds with 83 queries
