What gauge steel should I use for my floorboards? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old January 13th, 2007, 01:44 PM   #1
artistic_gore
I own @ halo
artistic_gore's Avatar
Send a message via AIM to artistic_gore
Default What gauge steel should I use for my floorboards?
I have to cut the rot out of my floor boards and replace and am curious as to what gauge steel I should be using. I don't have a caliper or I would figure it out for myself. Also does anyone sell a universal body mount floorboard replacement piece? The cup shaped piece that the bolt runs through for the cab mounts. 1 of mine needs replaced and two others are in sad shape.
Thanks in advance,
Bryce
artistic_gore is offline   Reply With Quote
Old January 13th, 2007, 02:34 PM   #2
VonDirt
VonDirt's Avatar
what vehical ?
VonDirt is offline   Reply With Quote
Old January 13th, 2007, 02:42 PM   #3
artistic_gore
I own @ halo
Sorry, its a 1980 toyota pickup.
Old January 13th, 2007, 04:03 PM   #4
Toivo
Feel lucky?
Toivo's Avatar
18 gauge should be suffiecient. I just did mine in my XJ.
Old January 14th, 2007, 10:41 AM   #5
VonDirt
VonDirt's Avatar
its not hyper critical, but heres a few things to consider on that topic.
if its undercoated it will be rotted back away from the edge. cut back to the fresh stuff or to the nearest fold.
all panels will have something like ribs, hats, or steps formed in them to give them rigidity. you dont have to make an exact copy of whats missing, but the bigger the hole, the more this becomes a consideration.
usually hole patches provide a great new place for moisture to hang out, (just like in all the factory spot welded locations). if its a long term fix, you might want to think about using a bodyshop grade panel epoxy or using seam sealer then rivets to squeeze out the excess.
then again, theres always duck tape if youre in a hurry
Page generated in 0.17726 seconds with 38 queries
