front and rear axle truss - Great Lakes 4x4. The largest offroad forum in the Midwest
Old January 10th, 2007, 11:09 AM   #1
yogi
swampstomper & old fart
yogi's Avatar
Default front and rear axle truss
what u think
yogi is offline   Reply With Quote
Old January 10th, 2007, 11:20 AM   #2
Me, I think trusses can be just as much trouble as they are good. Depends on the quality of the part, how closely it fits the axle.
If you have one that doesn't fit well, or isn't welded properly, then you end up warping the axle that your were trying to keep straight.
Old January 10th, 2007, 11:24 AM   #3
yogi
yogi's Avatar
took it off of this web site
T&T custums
thought it would help till i get a d-60
Old January 10th, 2007, 12:05 PM   #4
xj4life
xj4life's Avatar
man you're going at this XJ like a bat out of hell. i like your attitude
what axles and tires are you going to run? why do you need a truss? are you linking the rear?
Old January 10th, 2007, 01:23 PM   #5
ScOoTeR
hoo dat. wat.
ScOoTeR's Avatar
Aern't trusses for hernias?
IMHO, don't bother with a truss on your 30 if you're gonna change it.
@clarkstoncracker
Old January 10th, 2007, 01:26 PM   #6
Bones
Bones's Avatar
The only reason I would truss an axle is if you need to create your own link mounts 6-8" above the axle tube.
Inviscid Motorsports
Motorcity Machines
Branik Motorsports
Maxxis Tires
Raceline Wheels
PAC Racing Springs
Joint Clutch and Gear
Old January 10th, 2007, 02:05 PM   #7
VonDirt
VonDirt's Avatar
x2 on everybodys comments -
maybe it just gives you piece of mind but it seems like one of those items thats in a big gray area of "not enough information to know". its not thats its a bad idea or dosent work, its just really hard to gauge the value against what you actually need.
AND - like Jesus said, that warping thing is no joke. theres a right and a wrong way to install those and youll be looking for an upgrade alot sooner if it gets tweeked. its not that it cant be corrected (sort of) if it warps a little but the whole assembly has a memory from that point on and youll always be screwing around with it.
VonDirt is offline   Reply With Quote
Old January 10th, 2007, 02:58 PM   #8
yogi
yogi's Avatar
well ill be running 37in irocks
truss will help keep tubes from flexing
cheap fix till i can buy a d-60 front end
if it breaks its going to the junk pile anyway want to run it by the end of feb.
Old January 10th, 2007, 03:06 PM   #9
clarkstoncracker
lol
clarkstoncracker's Avatar
weren't you running 39" boggers or something on dana 30/35's on your TJ?
You going to put bigger axles under this?
Old January 10th, 2007, 03:16 PM   #10
yogi
yogi's Avatar
a no 42tsls on 44-60
yeah 60 front and rear
Old January 10th, 2007, 03:49 PM   #11
VonDirt
VonDirt's Avatar
time to rock and roll then
post a pic when youve got it dialed in
Old January 10th, 2007, 03:51 PM   #12
VonDirt
VonDirt's Avatar
hey, i missed that last pic for some reason - did you ever have issues with the 42s on your front 44 ?
Old January 10th, 2007, 04:10 PM   #13
The 39.5 boggers/ 30-35s are a guy named Greg, in my club.
Old January 10th, 2007, 04:13 PM   #14
BMFmike
meh.
BMFmike's Avatar
I am def going to be using this truss, I will probably order in a few weeks.
It will help seperate the lowers from the uppers, and I like the pinion guard. Probably will be a minimal strength gain going on a 14bolt but still serves a purpose.
Old January 10th, 2007, 04:25 PM   #15
clarkstoncracker
lol
I thought that was Yogi.
I know throwing mud is/was running 37 or 39 on baby axles, and they seemed to hold up
Old January 10th, 2007, 04:48 PM   #16
yogi
yogi's Avatar
yeah i broke shafts:tonka:
Old January 10th, 2007, 06:27 PM   #17
ScOoTeR
hoo dat. wat.
ScOoTeR's Avatar
Seems like you'll destroy the teeny R&P running the gears you'll need to turn 37's (in a D30).
@clarkstoncracker
Old January 10th, 2007, 06:46 PM   #18
xj4life
xj4life's Avatar
isnt 4.88 the deepest set you can get for a d30. yogi if you're really going to run a d60 soon i'd put as little money and time as possible into the d30. you might end up breaking stuff with 37's and your driving style but you'll save in the long run.
Old January 11th, 2007, 10:27 PM   #19
For a late model. CJ dana 30s do, or at least did, have aftermarket 5.38 gears available.
Old January 11th, 2007, 11:20 PM   #20
Tie Dyed
O.G.
Tie Dyed's Avatar
Send a message via AIM to Tie Dyed
44 in the rear, he twisted a shaft hitting the three wheel action.
2000 XJ with a 3 inch body lift
Tie Dyed is offline   Reply With Quote
Tags
bump 4 old threads
Page generated in 0.60363 seconds with 83 queries
