yj making some noise - Great Lakes 4x4. The largest offroad forum in the Midwest
Old January 10th, 2006, 03:33 PM   #1
muddslinger
muddslinger's Avatar
Send a message via AIM to muddslinger
Default yj making some noise
the last couple days ive been noticeing some noice from the rear end. when i hit bumbs and turn theres like a knock or clank or some weird sound, it almost sounds like somethings loose. i glanced under there and didnt notice anything standing out. i need some ideas of what it might be.
muddslinger is offline   Reply With Quote
Old January 10th, 2006, 03:39 PM   #2
BlooMule
Old School
BlooMule's Avatar
To be on the safe side, pull the cover and check the c-clips...it'd be nasty to lose an axle....
-rw-rw-rw
Old January 10th, 2006, 03:54 PM   #3
muddslinger
how do i do that?
Old January 10th, 2006, 07:56 PM   #4
snodogg
snodogg's Avatar
maybe it has something with you doing donuts and then hitting a curb
i told u your rear driver side tire was shaking
snodogg is offline   Reply With Quote
Old January 10th, 2006, 07:58 PM   #5
muddslinger
ya i know it was, still is. but i bumped that curb like a month ago lol. And i think this is on the opposite side to.
Old January 10th, 2006, 08:01 PM   #6
snodogg
snodogg's Avatar
well if you need a hand ripping it apart call me up ill swing by afterwork
Old January 10th, 2006, 09:18 PM   #7
clarkstoncracker
lol
clarkstoncracker's Avatar
Make sure one of your exaust brackets didn't dry rot apart.
Old January 11th, 2006, 12:18 AM   #8
Hacksaw
WWSD - What would stan do
Hacksaw's Avatar
check the simple things, exhuast, schocks, trac-bar bushings, sway-bar links (if there is a rear sway bar, I'm not to sure)
My guess is you will find something from the above list at fault, I highly doubt your axle is rattling around.
Old January 11th, 2006, 12:38 AM   #9
Chop
Mischievous Badger
Chop's Avatar
when i still had a track bar on the rear i had that same type of noise. then i cut the bar off and never heard that again. check those bushings and the leaf spring bushings
Old January 11th, 2006, 06:03 AM   #10
muddslinger
alright thanks for the advice, ill try to get it into my autoshop class today and get it on a lift to take a look. ill probably have more questions later.
Old January 11th, 2006, 04:29 PM   #11
muddslinger
ok i was just in the process of changing my rear shocks and i noticed whats making the noise. its either the track bar or sway bar(the bar that goes from one side of the axle to the other), the bracket on the axle is broken off near the top so one side of the bar is just sitting there. so my question is, if i just left it how it is or took it off altogether, would it be ok to drive? keep in mind this is my daily driver. what are my options here?
Old January 11th, 2006, 05:03 PM   #12
clarkstoncracker
lol
Cut it out of there.
My roomate's bushings went out up front, so we took out the bar, then when he replaced the bushings up front, we took out the rear one because that was becoming loud also.
Anyways, he couldn't tell a difference with it or without it on there.. On the otherhand, if you need to make a sudden move going 23084473 mph, it might effect it.
Not very many people running track bars/sway bars with YJ's.
Old January 11th, 2006, 05:21 PM   #13
muddslinger
thanks alot cc, consider it gone.
Page generated in 0.35063 seconds with 62 queries
