changing 92 explorer head gakset - Great Lakes 4x4. The largest offroad forum in the Midwest
Old January 9th, 2007, 04:59 PM   #1
xlinkinpark2438x
03 Rubicon
xlinkinpark2438x's Avatar
Default changing 92 explorer head gakset
i think i am going to try changing the head gasket on my 92 explorer this weekend because driving this jeep is just soo cold
does anyone have any tips on doing this
refering back to this
http://www.greatlakes4x4.com/showthread.php?t=15227
i hope that the problem is the head gasket
i guess i will find out this weekend
thanks
xlinkinpark2438x is offline   Reply With Quote
Old January 10th, 2007, 05:22 AM   #2
xlinkinpark2438x
03 Rubicon
soo no one has any tips or anything to say?????
Old January 10th, 2007, 08:45 AM   #3
the y-pipe bolts are horrible and don't cheap out on the gasket set. If you buy a cheaper set, i gurantee the lower intake gasket will leak, buy the better set. In my opinion with that many miles i would rather just buy a used motor. I replaced my wifes 94 4.0L for $400. You'll have close to that in a good head job, between gaskets and machine shop, and with that many miles on that 4.0L you can pretty much count on a cracked head or two. And after you seal up the top end and make it fresh again how's the lower end gonna handle it?
I did head gasket on my 93, had a bad valve on drivers side back cyl. and the center cyl. on pass side had a chunk of valve missing. I never had an overheating problem but both heads ended up being cracked and the cracks were not even in the combustion chambers of the bad cyl's.
Just my $.02
Old January 10th, 2007, 09:04 AM   #4
kevinr839
kevinr839's Avatar
Have you done a compression check yet, or have you put a air hold fitting in the spark plug hole and see where the air is going? I am thinking with it missing that bad and only 1 cylinder not changing rpm when plug is pulled and no antifreeze smoking heavily out the exhaust it might not be a head gasket.
Stuck injector sounds like a good possibility. Possibly a cracked spark plug? Maybe worn camshaft or bent or broken pushrod/rockerarm? I just hate to see you pull a head and it not be the problem.
kevinr839 is offline   Reply With Quote
Old January 10th, 2007, 01:37 PM   #5
xlinkinpark2438x
03 Rubicon
Originally Posted by xlinkinpark2438x View Post
i just went out there to check it out again and there is also oil at the exhaust manifold connection to the rest of the exhaust and i smell gas in the oil and looked in my radiator and i dont see any antifreeze. i do not think that it overheated because i usually watch all of my guages to make shure they dont go over the half way mark. (but maybe i didnt notice it) so i am not forshure that that it didnt overheat i also see some oil on that side of the block looked to be coming from the head gasket.
this is a reason why i think that it is a head gasket and once i get the head off ill find out more as in if it has a whole in the piston or cracked rings or stuck valve
the way i see it i know the head gasket is bad soo i mine as well work on that and hope for the best
Old January 12th, 2007, 07:45 AM   #6
kevinr839
kevinr839's Avatar
Watch for the bolts that hold the exhaust manifold to the head the like the top ones like to break off. Be sure to spend the money to have the head checked out and resurfaced at a machine shop, and unless you have soem seriously leaking valves do not do a valve job, that will save some stress on your rings.
Page generated in 0.30730 seconds with 41 queries
