zj lower control arms - Great Lakes 4x4. The largest offroad forum in the Midwest
Old January 7th, 2007, 10:01 PM   #1
mudbogger
Woody
Default zj lower control arms
my lower control arms are to short on the rear of my 93 zj. i think i need about three more inches out of them. is there anything i can do to make them ones work without buying adjustables ones. no cash flow rate now so trying to find a way to make this work. thanks
mudbogger is offline   Reply With Quote
Old January 8th, 2007, 05:49 AM   #2
fr3db3ar
KISS MY AVATAR
fr3db3ar's Avatar
I've seen plenty of ghetto extensions.....but I couldn't recommend them
Old January 8th, 2007, 08:32 AM   #3
Jeeperz Creeperz
GL 4x4 Vendors
Jeeperz Creeperz's Avatar
3 more inches? That's a lot! How much lift do you have?
Jeeperz Creeperz, Inc.
1627 Eureka Rd
Wyandotte, MI 48192
734-281-8141
M-F 10am-7pm
Sat 10am-3pm
www.jeeperz-creeperz.com
Old January 8th, 2007, 09:15 AM   #4
fr3db3ar
KISS MY AVATAR
fr3db3ar's Avatar
I was thinking the same thing....unless you're moving your axles rearward...I have 5 lift on my ZJ and my lower is only 3/8" longer
Old January 8th, 2007, 10:35 AM   #5
mudbogger
Woody
k well i dont know excactly tp be honest i has 6-7 inches on it with a front to rear swap and 3 inch spacers bought adjustable track bars front and rear bot now i just need to center my rear tires back up in the wheel well. and yes the axle needs to go rear ward
Old January 8th, 2007, 12:26 PM   #6
greenmeanie
greenmeanie's Avatar
there was a post a month or two ago about someone who made some. looked to be pretty decent quality. try searching for it. i think it was in the fab section. i think it might have been bluexj???
greenmeanie is offline   Reply With Quote
Old January 8th, 2007, 12:30 PM   #7
Icebreaker88
Icebreaker88's Avatar
Grandman extended his stock arms by cutting them in half and using box tubing in the center of them.
[QUOTE=TurdBronco;1095911]I don't usually race cause it is still a focus.[/QUOTE]
Icebreaker88 is offline   Reply With Quote
Old January 8th, 2007, 02:12 PM   #8
mudbogger
Woody
could i use a top link of the 3 point hitches of tractors it pretty simialar to the adjustable control arms from sky jacker. this is a daily driver to so i dont know if using something like that would affect anything
heres the link
http://www.mytscstore.com/detail.asp...roductID=17061
Old January 8th, 2007, 02:52 PM   #9
Icebreaker88
I have heard those are no good for susp. link ends
Old January 8th, 2007, 04:41 PM   #10
Kawierider
Kawierider's Avatar
I believe the previous thread was in the fab section. He took a longer tube control arm welded in a bung, and then used I beleive a 1 inch grade 8 fine thread bolt with a heim welded to it or a similar setup.
Old January 8th, 2007, 06:29 PM   #11
Roadhouse
DrivewayJeeper
Roadhouse's Avatar
holy crap 6-7" of lift on stock arms........that has to ride nice.
Old January 8th, 2007, 07:39 PM   #12
Grandman
do i look old !
Grandman's Avatar
Yep and it has worked well for me . Mine has 7.5" lift and they were only extended about 1.1/4 if i recall . Top and bottom do not extend the same amount . Do you lower then do the uppers last . Set pinion angle while your at it .
1x2 rectangular tubing fits in the lowers nicely , once welded up there stronger then orginal .
Upper set a heavy wall section of pipe into them stretch and weld it up . I have never broke or bent one of these .
Old January 8th, 2007, 08:47 PM   #13
sglide
co captain of cubes pants
sglide's Avatar
i did prety much the same thing, exept in the front i used broken d35 axel shafts clamped inside control arms and welded.
i beat the hell out of mine and there fine
sglide is offline   Reply With Quote
Page generated in 0.28207 seconds with 62 queries
