O2 Sensor question - Great Lakes 4x4. The largest offroad forum in the Midwest
Old January 5th, 2007, 06:33 PM   #1
grize
What are you looking at??
grize's Avatar
Default O2 Sensor question
had issues with my cat and O2 sensor (after cat) so I unpluged the sensor and replaced the whole mess with a piece of pipe, Read couldn't afford proper fix, so now I'm getting some work done (head gasket)and I'm being told that even if I dont have a cat I still need the O2 sensor to make my truck run right. I don't have the original sensor so my question is will I be any better off buying the sensor and hooking it up without the cat than I am with the pigtail taped off and tucked away?
btw this is on a 97 2.2 S-10
grize is offline   Reply With Quote
Old January 12th, 2007, 05:45 PM   #2
sQUEAK003
Irish R&B Singer
sQUEAK003's Avatar
bizza bump
'09 "Sparkly Tan" Jeep Patriot
http://badges.fuelly.com/images/smallsig-us/306663.png
CLICK HERE TO GET RID OF ME
Originally Posted by PCK_4xCustoms View Post
cunt punt, it's like a reset switch for women.
sQUEAK003 is offline   Reply With Quote
Old January 12th, 2007, 06:37 PM   #3
Bones
Bones's Avatar
Do you still have the pre cat sensor hooked up?
Do you know if you have a pre and post cat o2 sensor?
Sounds like you have a pre and a post cat sensor, Even if you instal the post cat sensor into the exhaust, you will always have a check engine light since the motor thinks your CAT has failed.
However, if you still have the pre cat sensor hooked up, I *think* the engine will run right, except for the CEL
Inviscid Motorsports
Motorcity Machines
Branik Motorsports
Maxxis Tires
Raceline Wheels
PAC Racing Springs
Joint Clutch and Gear
Old January 12th, 2007, 07:22 PM   #4
grize
grize's Avatar
yes, the pre cat sensor is hooked up, working
yes, there are two sensors
I dont care if the light is on just wanted to know if having the sensor in place with out the cat is better than not having one at all(old sensor is gone ,unplugged, wiring taped and tucked up on the crossmember)
Old January 18th, 2007, 02:37 PM   #5
GetItOffroadGMC
GetItOffroadGMC's Avatar
I have been told that if you run the post cat sensor with a trap it will cancel the CEL. Have your exaust guy weld in a V shaped piece to trap heat near the second sensor.
GetItOffroadGMC is offline   Reply With Quote
Old January 22nd, 2007, 08:42 PM   #6
grize
grize's Avatar
...UPDATE...
ponied up the $79.99 and bought the sensor and O2 bung and had it welded in, so far no light, will have to wait and see if it comes back, it took almost two weeks for the light when I removed it in the first place so...
Old January 25th, 2007, 08:03 PM   #7
DodgeitRamit
DodgeitRamit's Avatar
It should be fine i run True duals on a 96 ram pre and post cat sensor, no cats, and my check engine light has never come on and gas mileage wasn't really effected
DodgeitRamit is offline   Reply With Quote
Old January 26th, 2007, 03:25 PM   #8
grize
grize's Avatar
still no light and gas mileage is right around 27 mpg, so all seems well...
Old February 6th, 2007, 01:21 AM   #9
sQUEAK003
Irish R&B Singer
sQUEAK003's Avatar
so did that kid ever let u look at that jeep or no
Old February 6th, 2007, 04:57 PM   #10
grize
grize's Avatar
Nope just one excuse after another, then nothing, so :stan3: BTW still no light and truck running great
Old February 10th, 2007, 02:56 AM   #11
sQUEAK003
Irish R&B Singer
sQUEAK003's Avatar
what a douch nozzle (the nozzle touches the dirty part)
Page generated in 0.31740 seconds with 56 queries
