bolt pattern conversion - Great Lakes 4x4. The largest offroad forum in the Midwest
Old January 5th, 2007, 09:15 AM   #1
greenmeanie
greenmeanie's Avatar
Default bolt pattern conversion
on a dana 44 would it make the axle weaker if i drilled it for a 4.5 inch bolt pattern??
i've seen some axles w/ holes for both 4.5 and 5.5 inch patterns. what would you suggest to line up the holes properly so they aren't drilled off center?? i was thinking just line up another shaft that has the pattern in it.
i think one of my buddies would assist me; he has a lathe if that would help.
i found some adapters, but if i could drill them out for a lot less; i'd rather do that. thanks!
greenmeanie is offline   Reply With Quote
Old January 6th, 2007, 08:10 PM   #2
sglide
co captain of cubes pants
sglide's Avatar
why dont you use 5.5 rims? there plentifull, shit ill give you a set myself if itll keep you from drilling your flanges (ya its a bad idia!)
sglide is offline   Reply With Quote
Old January 6th, 2007, 09:07 PM   #3
greenmeanie
already have a matching set w/ the backspacing i want and my tires already mounted on them. i'll probably get some adapters, just thought i'd check on the whole drilling issue....
Old January 7th, 2007, 08:22 AM   #4
sglide
sglide's Avatar
dont do it the list of things that can go wrong would make my hands cramp from typing
get the adapters and save$ in the long run
Old January 7th, 2007, 08:30 AM   #5
Cooter
Dad Kickin' It OldSkool
Cooter's Avatar
Having the axles redrilled isn't a problem- Moser does it all the time. However, you will have issues with the center register, since it is too big for the 5 on 4 1/2
Old January 7th, 2007, 08:48 AM   #6
sglide
sglide's Avatar
they do it the right way with the right tools.
axle flanges are heat treated improper drilling can couse fractures you wont see w/out magnaflux and even then you cant trust them
Old January 7th, 2007, 09:12 AM   #7
Trail Junkie
iamfawkinwithyou
Trail Junkie's Avatar
Dosent some one make a spacer that goes from 5 on 5.5 to 5 on 4.5???
Old January 7th, 2007, 09:36 AM   #8
sglide
sglide's Avatar
yes
Old January 7th, 2007, 10:07 AM   #9
Cooter
Cooter's Avatar
Umm, yeah.
They redrill them with a drill press...
Old January 7th, 2007, 11:03 AM   #10
Jeeptj1999
Jeeptj1999's Avatar
Umm, yeah.
Agreed lol. They have a jig set up and do it with a small horizontal mill. I can do them but it would take a week or so turn around and set ya back $55.
Jeeptj1999 is offline   Reply With Quote
Page generated in 0.21809 seconds with 53 queries
