Power steering - Great Lakes 4x4. The largest offroad forum in the Midwest
Old January 4th, 2007, 09:29 PM   #1
artistic_gore
I own @ halo
artistic_gore's Avatar
Send a message via AIM to artistic_gore
Default Power steering
I almost forgot. I would have posted this in the other thread but I wanted it to get specific attention (yes I love attention). Anyway, My truck currently doesn't have power steering and is a bitch to drive around even with the 31s so I am curious to know how I would know if my push/pull steering box is power steering capable. Is that even possible? Did they use the same box but with a power steering option? Or will I have to find a box from a truck with power steering to do the swap? I've got the pump and resevoir with the 22R I'm putting in so I guess what I'm asking is if it's now just a matter of adding hoses to the whole ensamble. I guess I'm getting tired. Sorry if this doesn't make a whole lot of sense. As always any help would be appreciated.
Thanks,
Bryce
artistic_gore is offline   Reply With Quote
Old January 4th, 2007, 10:20 PM   #2
nmeinc
Parts Galore Spokesmodel
nmeinc's Avatar
No the box you have will not be able to be converted to power steer. if you could find a power push/pull the pump on the 22r will work.
the best choice is to Get an IFS box and get a Crossover arm for the passenger side. or get a High steer set up.
if you decide to go IFS box i have a spare for sale. JCR might be able to fab an arm.
nmeinc is offline   Reply With Quote
Old January 4th, 2007, 11:24 PM   #3
What he said.
As I noted earlier, crossover steering requires enough spring lift that the drag lift & pitman arm don't hit the springs.
I have a couple power steering boxes for the push-pull type steering, as well as a 3" drop steering arm for push-pull.
Normally I sell them on ebay, since they are very popular with FJ40 owners, and old Ford F100. The Ford guys often pay $100 or more for them.
To go with crossover steering, you need to build up a frame mount. Mine I did like this:
Then you bolt on a IFS toyota 4wd steering box:
You can see why you need some lift. Those springs are about 4" taller than stock. With the large amount of uptravel you can get, you can and will hit the spring into the steering arm.
Old January 5th, 2007, 03:47 PM   #4
nmeinc
nmeinc's Avatar
Well part of that is true.
depending on how you mount the box. you can either get a flat Pitman arm (trailgear) or tilt the box.
mine is an 85 frame with the box pushed into the rad support and tilted. the waggy springs are about 2-3 in of lift.
mine during mock up
Old January 5th, 2007, 03:58 PM   #5
I run 83 rears up front on mine. My box is also tilted as much as I could get, cut out quite a bit of the radiator support.
My front springs sagged, which accentuated the problem, I think.
For reference, looking at the castle nut on pitman arm/drag link, with my sky arm, I now have less than 1/16" clearance between that nut and the frame, so mine is tucked as high as possible. The sky arm is huge. I think it would be impossible to break.
My stock retapered arm took a couple hits, and I was worried it would break at the worst time in tellico. There, I was stuffing the front wheels way more than I ever did up here.
Old January 5th, 2007, 05:02 PM   #6
nmeinc
nmeinc's Avatar
Here another referance pict just for fun
Old January 5th, 2007, 09:16 PM   #7
My frame is a 1st gen, which also may account for some differences. 1983 longbed, I have a 2nd gen cab. My body mounts are kinda in the correct location, but everything on my truck is a bit wierd.
Page generated in 0.27429 seconds with 44 queries
