18' enclosed trailer - Great Lakes 4x4. The largest offroad forum in the Midwest
Old January 4th, 2007, 03:38 PM   #1
grassracer25
grassracer25's Avatar
Default 18' enclosed trailer
Home built enclosed trailer, V-nose, drive in drive out, surge brakes. Holds 4 sleds or 6 ATV's. Measures 20 1/2' down the center inside, 96" wide on the inside, 4' sides, 55" center height. Was built in fall 2000. Needs paint, a patch on the side, a patch on the floor in the front. I would do this myself, but have no shop big enough to do it.
$1400 obo
ID:	5642   Click image for larger version
ID:	5643   Click image for larger version
ID:	5644   Click image for larger version
grassracer25 is offline   Reply With Quote
Old January 4th, 2007, 08:32 PM   #2
jeepguy74
jeepguy74's Avatar
how heavy is this?
Old January 4th, 2007, 10:05 PM   #3
Symmes
How does it pull?
Symmes is offline   Reply With Quote
Old January 5th, 2007, 03:03 PM   #4
grassracer25
I towed it empty with my wifes Libby no problem at all. It pulles great behind a 1/2 ton P/U loaded with four sleds in it.
I've never taken it across a scale so I don't know how heavy it is.
Old January 7th, 2007, 12:56 AM   #5
Mclovin
"The Situation"
Mclovin's Avatar
if it were taller id consider it
Old January 7th, 2007, 11:19 AM   #6
jeepguy74
jeepguy74's Avatar
what are the sides made out of?err what all did you use to buile the encloseure and is it just a snowmobile trailer with a cap built on it or is it all home built
Old January 8th, 2007, 07:43 PM   #7
grassracer25
It is all home built, 2x2 square tube frame, plywood sides, sheetmetal roof, steel floor
Page generated in 0.24289 seconds with 45 queries
