scout 44 in a cj soa. i need steering ideas - Great Lakes 4x4. The largest offroad forum in the Midwest
Old January 3rd, 2007, 09:38 PM   #1
snocross2xtremes
snocross2xtremes's Avatar
Default scout 44 in a cj soa. i need steering ideas
the only way i can do it right now would be to put the steering under the springs and it like hangs really low.. and the only high steer kit i found was like 800 bucks.. pics would be great
Old January 3rd, 2007, 11:06 PM   #2
PavementPounder
PavementPounder's Avatar
Different knuckles? Are they flat-tops now?
Old January 4th, 2007, 04:27 PM   #3
Cooter
Dad Kickin' It OldSkool
Cooter's Avatar
You have to change the knuckles- the scout ones are horrible.
Old January 4th, 2007, 04:39 PM   #4
PavementPounder
http://www.greatlakes4x4.com/showthread.php?t=23034
I don't really know if these would solve the problem, but they are the right pattern.
Old January 4th, 2007, 08:25 PM   #5
78cj7
build it break it learn
78cj7's Avatar
I used chevy flat top outer knuckles and jeep dana 30 spindles, you can use chevy spindles but if you use the dana 30 spindles you can use the scout brakes which are bigger and IIRC they have a bigger piston than the chevy brakes. The downside is that now I need a bigger m/c and will probably go with the e350 or c20 as they have more volume.
I then used a t style steering setup you will find this necessary if you go to one ton steering as most arms won't have the clearance required unless you move your steering box forward. You can make your own tie rod and drag link like I did and save 100.00 or go to parts mike.com and get a t-style steering setup custom made for 269.00.
He also has the arms and spacers you will probably need as well to go with your flat tops. I can get you pics tommorrow if you want as I just finished the steering today. and now that everything works I will take it all back apart tommorrow and weld it all solid .
78cj7 is offline   Reply With Quote
Page generated in 0.29837 seconds with 38 queries
