390 Issues - Great Lakes 4x4. The largest offroad forum in the Midwest
Old January 3rd, 2007, 01:42 PM   #1
Mijeeper CJ 7
Mijeeper CJ 7's Avatar
Default 390 Issues
I've got a 76' F150 with a 390 4 barr.carb 4 speed manual trans. It had a exhaust leak that I fixed and now it's back firing through the carb. It only does it under power. I can rev it in neutral & no back fire. I replaced the vaccume lines and put a new carb gasket on it. Checked the timing and it seems to be fine. Put new mufflers on it. What am I missing here?
Mijeeper CJ 7 is offline   Reply With Quote
Old January 4th, 2007, 12:24 AM   #2
Grandman
do i look old !
Grandman's Avatar
Do a compresson test on it . FE blocks did not have hardened valves . No lead fuel takes out the exhaust valves .
Popping thru the carb would indicate an intake valve problem rather then exhaust valve though .
Intake valve to tight ? they been adjusted lately ?
Id start with the compression test . Have a cyl down then check adjustment .
Old January 4th, 2007, 07:30 PM   #3
Mijeeper CJ 7
Thanks G-Man
Page generated in 0.18129 seconds with 32 queries
