84 Bronco *SOLD* - Great Lakes 4x4. The largest offroad forum in the Midwest
View Poll Results: Thought it had a 302, has a 351 though. What is a reasonable price?
$500 9 81.82%
$600 0 0%
$700 1 9.09%
$800 1 9.09%
$1000 0 0%
Voters: 11. You may not vote on this poll
Old January 1st, 2007, 09:54 PM   #1
cjaholic
(o )( o)
cjaholic's Avatar
Exclamation 84 Bronco *SOLD*
It has a running 351, C6, NP208, 9" rear and D44 TTB. Has a hard top, its in OK shape, D-side floor has a hole in it and some rust above the rear wheel wells. It does have the complete dash and grill, just not on it at this time. Tires on it are junk, they are 33x12.5x15.
Also have some parts for it:
Right front fender and headlight bezel
Bucket of hub parts
Steering wheel
New brake pads and shoes
New wheel cylinders and 1 rebuild kit
Oil filter
Thermostat
Air filter housing
Name:	bronco drivers side.jpg
ID:	5732   Click image for larger version
Name:	bronco pass side.jpg
ID:	5733   Click image for larger version
Name:	bronco drivers wheel well.jpg
ID:	5734   Click image for larger version
Name:	bronco pass wheel well.jpg
ID:	5735   Click image for larger version
Name:	bronco drivers rear corner.jpg
Name:	bronco pass rear corner.jpg
ID:	5737   Click image for larger version
Name:	bronco tailgate.jpg
ID:	5738   Click image for larger version
Name:	bronco hitch.jpg
cjaholic is offline
Old January 7th, 2007, 04:02 PM   #2
cjaholic
(o )( o)
cjaholic's Avatar
A few more.
Name:	bronco ds hole.jpg
ID:	5740   Click image for larger version
Name:	bronco interior.jpg
ID:	5741   Click image for larger version
Name:	bronco engine.jpg
cjaholic is offline
Old January 13th, 2007, 07:53 AM   #3
slow96hater
rob
slow96hater's Avatar
would you sell the whole truck?
i see the hole in the floor, hows the rest of the floor tho?
slow96hater is offline
Old January 13th, 2007, 11:19 AM   #4
Blazin79
Blazin79's Avatar
how much for rearend axle? thanks
Blazin79 is offline
Old January 13th, 2007, 05:43 PM   #5
cjaholic
(o )( o)
cjaholic's Avatar
The rest of the floor has no holes. The rust on the fenders could be removed with cut out flares.
cjaholic is offline
Old January 13th, 2007, 06:30 PM   #6
BlaineWasHere
GVSU Jeeper
BlaineWasHere's Avatar
Send a message via AIM to BlaineWasHere
Is the front an HP44? lug pattern and WMS width?
BlaineWasHere is offline
Old January 13th, 2007, 07:59 PM   #7
bj house
bj house's Avatar
I might be mistaken but that year Bronco would have a TTB (not solid) front axle. I doubt that you want that for anything other than another similar Bronco or Fseries.
bj house is offline
Old January 13th, 2007, 08:34 PM   #8
cjaholic
(o )( o)
cjaholic's Avatar
Thank you bj house, the front is the twin traction beam and uses a D44 third member.
cjaholic is offline
Old January 14th, 2007, 12:11 AM   #9
Bronco Sally
Lets go wheelin
Send a message via MSN to Bronco Sally
How much for the carb?? 2bbl correct?? and pics of the tack?? and price.. Thx Mike
Bronco Sally is offline
Old January 14th, 2007, 07:13 PM   #10
cjaholic
(o )( o)
cjaholic's Avatar
Bronco Sally, check your PM's.
cjaholic is offline
Old January 19th, 2007, 08:42 PM   #11
cjaholic
(o )( o)
cjaholic's Avatar
New price $500
cjaholic is offline
Old January 25th, 2007, 11:06 AM   #12
Dieselphreak2000
Somehow still alive..
Dieselphreak2000's Avatar
pics of plow?
Dieselphreak2000 is offline
Old January 28th, 2007, 06:32 PM   #13
cjaholic
(o )( o)
cjaholic's Avatar
frame and front suspension, both np208's, and maybe the extra front coils are all spoken for.
Still have the 302, both C6's w/ t-case adapters, fenders, hood, and doors-(will fit F-150 and F-250), and hard top. The plow doesn't have a pump but does come with both angle and lift cylinders, can use a winch to lift and I have two new tractor 3-point top links to take place of angle cylinders, frame for ford.
Everything cheap or accept
cjaholic is offline
Old January 28th, 2007, 06:38 PM   #14
Dieselphreak2000
How much for the doors? Is that rust on the bottom thru, or surface.
Last edited by Dieselphreak2000; January 28th, 2007 at 06:40 PM. Reason: I'm an idiot.
Old January 28th, 2007, 06:44 PM   #15
vwBOY
it's how i roll
vwBOY's Avatar
how much for the hitch and would that fit a 94 f-150
vwBOY is offline
Old January 28th, 2007, 07:22 PM   #16
overbuiltyj
overbuiltyj's Avatar
If you will sell just a Tcase adapter,How much and will you ship?Thanks
overbuiltyj is offline
Old January 28th, 2007, 07:30 PM   #17
cjaholic
(o )( o)
cjaholic's Avatar
The rust on the doors is surface. $75 complete
Yes the hitch will fit a 94 F-150. $35
Would like to keep the t-case adapters with the trans's FOR NOW, if nobody wants the trans's I'll seperate.
cjaholic is offline
Old January 28th, 2007, 07:35 PM   #18
vwBOY
it's how i roll
vwBOY's Avatar
let me see what i got going on and is it off the truck yet
vwBOY is offline
Old January 28th, 2007, 07:39 PM   #19
cjaholic
(o )( o)
cjaholic's Avatar
Can have it off the truck mon. night.
cjaholic is offline
Old January 28th, 2007, 07:40 PM   #20
vwBOY
it's how i roll
vwBOY's Avatar
ok how far are you from howell
vwBOY is offline
Page generated in 0.42629 seconds with 85 queries
