Axle shaft Q. - Great Lakes 4x4. The largest offroad forum in the Midwest
Old December 25th, 2006, 07:19 PM   #1
redmud
10 0011 10101
redmud's Avatar
Default Axle shaft Q.
I was changing my U-joints last friday, and due to 11 years worth of rust (don't flame me, I haven't had the jeep anywhere near that long) the stub shaft basically exploded when i pressed out the joint. I did get the circlips out first, it was just really old. anyway. I had a spare axle shaft out of a HP dana 30 that had a ABS tone ring on it. the blowed up stub shaft has a tone ring that is approx. 1.25" long, and the spare shaft had on that's @ three quarters of an inch. the spare supposedly came out of a '93 XJ. now, my ABS works with the smaller tone ring, and it fit the 297 joint, can anyone tell me what that shaft is out of?
redmud is offline   Reply With Quote
Old December 25th, 2006, 07:20 PM   #2
redmud
10 0011 10101
redmud's Avatar
cliffs notes version: replaced my stub shaft with one with a significantly smaller ABS tone ring, supposed to be out of 93 XJ, ABS works, and a TJ u joint fit. just curious what the axle shaft was out of, I thought mid 90's xj's used 260 joints.
Old December 25th, 2006, 07:27 PM   #3
lgottler
lgottler's Avatar
I'm pretty sure they used the 297/760's....at least thats what my '91 used...
lgottler is offline   Reply With Quote
Old December 25th, 2006, 08:20 PM   #4
redmud
10 0011 10101
redmud's Avatar
I bought the HP 30 used, maybe he just stuck a random axle shaft in it?
Old December 26th, 2006, 12:24 PM   #5
EMTimZJ
What emergency?
EMTimZJ's Avatar
It is most likely from an XJ with ABS. Earlier XJ's did have the smaller 260 u-joint unless it had ABS, then it got the larger 297/760 joint.
HTH
EMTimZJ is offline   Reply With Quote
Old December 26th, 2006, 12:29 PM   #6
redmud
10 0011 10101
redmud's Avatar
HTH
Thanks, that's good to know the for the next time I go junkyard crawling.
Page generated in 0.33754 seconds with 41 queries
