another zj question - Great Lakes 4x4. The largest offroad forum in the Midwest
Old January 6th, 2006, 05:31 PM   #1
snodogg
snodogg's Avatar
Default another zj question
when i think i fixed all the stuff wrong with it another thing comes up
so when im cruising at about 50 mph and let off the gas the rpms go from about 2000 to 1500 and then back up to 2000 and then back down and so on till i get to about 45 mph then it stops. it jerks the jeep around pretty good when it does this and after driving around in traffic doing about 50 it starts to make me feel a lil sick. any ideas?
snodogg is offline   Reply With Quote
Old January 6th, 2006, 05:38 PM   #2
Bones
Bones's Avatar
i would guess
#1- low trans fluid
#2- bad torque converter
#3- bad valve body
#4- some freekish calibration glitch
#5- OD band is worn (but still shouldn't cycle engage/disengage unless there is a pressure issue.
Chenge your fluid and see what happens. Your speedo is working correct right? No check engine light?
Inviscid Motorsports
Motorcity Machines
Branik Motorsports
Maxxis Tires
Raceline Wheels
PAC Racing Springs
Joint Clutch and Gear
Old January 6th, 2006, 05:42 PM   #3
snodogg
snodogg's Avatar
i changed the trans fuild last week and that didnt fix it...no check engine light, the fuild level is fine...
Old January 6th, 2006, 05:44 PM   #4
snodogg
snodogg's Avatar
the speedo is right too its seems to stop if i turn off the overdrive cruise for like 10 seconds then turn the overdrive back on...its just a lil wierd that it only does this between 45 and 50
Old January 6th, 2006, 06:39 PM   #5
Jeeperz Creeperz
GL 4x4 Vendors
Jeeperz Creeperz's Avatar
Sounds like the converter is shuddering when it's trying to lock up.
Wait, this happens when you let off the gas? Not while at steady cruise or accelerating?
Old January 7th, 2006, 01:23 PM   #6
snodogg
snodogg's Avatar
yep happens when i let off the gas at about 50
Old January 7th, 2006, 05:19 PM   #7
5.9zj
5.9zj's Avatar
try checking/replacing your throttle position sensor. It can cause an engine to surge.
5.9zj is offline   Reply With Quote
Old January 7th, 2006, 06:19 PM   #8
clarkstoncracker
lol
clarkstoncracker's Avatar
I had this happen to me in a dodge avenger about 4 years ago, ended up being the TPS...
Old January 12th, 2006, 12:53 PM   #9
Monster4.0
Monster4.0's Avatar
I think your converter is going in and out of lock up. It is common.
Old January 18th, 2006, 09:25 AM   #10
fr3db3ar
KISS MY AVATAR
fr3db3ar's Avatar
I agree with 5.9 and CC.....check your TPS. I need to replace mine to make my cruise work right again.....it want's to fluctuate the rpms and twitchs .
Page generated in 0.25029 seconds with 53 queries
