CJ NT D44 question - Great Lakes 4x4. The largest offroad forum in the Midwest
Old December 24th, 2006, 08:06 PM   #1
cannaert
No more Jeep
cannaert's Avatar
Default CJ NT D44 question
Ok i picked up this Rear 44 for Drit cheap need to put back togther and I nocticed the on axle shaft has a Sealed roller bearing and the other is a taperd baering on it. I wondered if any one know what one i should buy to redo the whole thing.
Thanks Chris
EDIT: Did the early 44's Come what a trac-loc at all. I noctice on the side of the carrier it has 2 small holes on each side with what looks to me like Clutchs on both sides
Old December 26th, 2006, 02:10 PM   #2
shawn
Resident HVAC/R Jambi
shawn's Avatar
Looks like an open carrier to me.
But, if you are talking about the axle shaft bearings, I am pretty sure they should be tapered roller bearings, that are pressed on and then pressed on after that are the "wedding ring." Those are not C-clip, so they shouldn't have ball or straight drum roller style bearing, it should be a tapered roller bearn, and the outer race should be in the end of the axle tube.
Old December 30th, 2006, 09:22 PM   #3
cannaert
No more Jeep
cannaert's Avatar
HOW can i remove the "Wedding ring" with out a press?
Also were could i get new ones if I need them?
any one have a part # for the 72-75 D44 carriare bearings at all?
Old December 30th, 2006, 09:48 PM   #4
To answer your question, 72-75 Dana 44s were available with the trac loc differentials. Some renegades had them, although my 75 renegade did not.
You really can't usually do the bearings without a press. So take them to your auto parts store and they'll swap them for a few bucks.
I bet a search of 4wd hardware or quadratec will turn up the part number for your carrier bearings.
Old January 2nd, 2007, 06:35 PM   #5
shawn
shawn's Avatar
You don't reuse them. The get cut or drilloed off (drill it with a hefty drill, then wack it with a chizle and they usually POP, allowing you to slide it off).
Old January 2nd, 2007, 10:30 PM   #6
cannaert
No more Jeep
cannaert's Avatar
So the wedding rings are a one time thing. I dont really need them then. Thats Cool then I can get them off pritty fast now.
Old January 2nd, 2007, 10:45 PM   #7
greenjeep
greenjeep's Avatar
That is a trac lock carrier.
greenjeep is offline   Reply With Quote
Old January 3rd, 2007, 03:50 PM   #8
shawn
shawn's Avatar
No, you need them, you have to buy new ones. That is what keeps that bearing on and (actually) keeps your axle shaft in your axle.
Have you thought that maybe you should hand this off to somebody to do for you? Kinda sounds like you are getting more and more lost on this one.
Old January 3rd, 2007, 07:49 PM   #9
cannaert
No more Jeep
cannaert's Avatar
I never done an axle that does not have the C-clip holding the shafts in.
this will be the 5th one I have put together. Ill have to call CarQuestor or Napa tommrow see if I can track them down.
Old January 3rd, 2007, 09:44 PM   #10
snocross2xtremes
snocross2xtremes's Avatar
stubs does it!
Old January 4th, 2007, 09:01 PM   #11
cannaert
No more Jeep
cannaert's Avatar
Found the bearing retaning ring ( wedding rings) No i need the right part number for the Axle bearings.
Aslo I the Axle shafts had one w/ a tapered bearing and one w/ sealed ball bearing. Any one know either of the two kinds partnumbers.
Old January 5th, 2007, 10:02 PM   #12
shawn
shawn's Avatar
Call Rieder Racing in Taylor, they will be able to tell you (and probably have it on the shelf) everything you need.
Page generated in 0.30204 seconds with 59 queries
