Riddle me this please - Great Lakes 4x4. The largest offroad forum in the Midwest
Old December 21st, 2006, 04:51 PM   #1
mpwal099
Stick it up your ass
mpwal099's Avatar
Default Riddle me this please
I am changing the front struts on my DD. How in the name of all that is holy or unholy can I keep the inner shaft from spinning so that I can remove the top nut? TIA!
and as a side note. If the world around here made a 13/16 box wrench I would not be asking
mpwal099 is offline   Reply With Quote
Old December 21st, 2006, 05:20 PM   #2
Yetti
Buy a Fiat! Save the UAW!
Yetti's Avatar
believe it or not theres a special tool for holding it down the center of a socket while your strut is held in the compressor. I use a pair of very worn out visegrips. they have all the teeth rounded off from years of use. that way the center shaft doesn't get scratched from spinning while held.
Yetti
Old December 21st, 2006, 05:22 PM   #3
mpwal099
mpwal099's Avatar
Thanks Yetti. I have tried the vice grips and pipe wrenches but the darn thing just keeps spinning.
Old December 21st, 2006, 07:21 PM   #4
greenmeanie
greenmeanie's Avatar
i used channel locks over the bump stop (if yours has one)
greenmeanie is offline   Reply With Quote
Old December 21st, 2006, 10:15 PM   #5
badazzamc
Get Some
badazzamc's Avatar
most struts have a flat area where you can put an open end wrench on it. you will have to take the nut loose with a wrench instead of a socket though.
are you using an impact or just a ratchet?
Old December 21st, 2006, 10:57 PM   #6
mpwal099
mpwal099's Avatar
Thanks for the replies guys. I finally got it. My strut had no place to grab onto it what so ever. Normally I have been able to use a set of vice grips and voila, it spins right off. shoot my axle swap was easer than that thing tonight :miff:
Page generated in 0.15841 seconds with 41 queries
