Anybody see a problem? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old December 21st, 2006, 03:34 PM   #1
fr3db3ar
KISS MY AVATAR
fr3db3ar's Avatar
Default Anybody see a problem?
useing 1.5" black pipe (thick wall) for just the ends of my control arms that hold the bushings? I had some (cheap ass as far as I'm concerned) adjustable control arms "DW Customs". They made them using tractor heim joints on the upper control arms with a piece of tube in the center (tacked on either side of the heim so it could only slide back and forth about 1/4") Which is stupid and I should have done more research.
Anyway.....I'm replacing those ends with a bushing end.
Thoughts? These are for front uppers on the body end.
Old December 21st, 2006, 03:46 PM   #2
Grandman
do i look old !
Grandman's Avatar
I dont see an issue . Hell the orginal arms are really thin . 2 metal tabs for the most part with the bushing stuck in them .
by the way i played with a couple of them tractor joints too that i bought at TSC . Waste of time for sure .
Old December 21st, 2006, 03:48 PM   #3
VonDirt
VonDirt's Avatar
pipe tends to be softer which isnt the best for that application. i would really recommend DOM or the like, if its seam welded, have that side perpindicular to the opposing tube so the weld covers each side 50/50.
im just down the road from you if you need a hand with it - i may have some in stock, ill check when i get a minute.
VonDirt is offline   Reply With Quote
Old December 22nd, 2006, 12:56 AM   #4
dune coon
do work
dune coon's Avatar
fr3d, I'm using these for mine...You can buy them with the sleeve for $9 dollars more.
http://www.polyperformance.com/shop/...&cat=28&page=1
dune coon is offline   Reply With Quote
Old December 22nd, 2006, 06:20 AM   #5
fr3db3ar
KISS MY AVATAR
fr3db3ar's Avatar
I've got some fixed arms I can cut the ends off of. I was just trying to save some energy and cutting wheels.
Old December 22nd, 2006, 09:13 AM   #6
redmud
10 0011 10101
redmud's Avatar
So no TSC heim joints? I was thinking the same thing for control arms. crap. I was all excited about 'em.
redmud is offline   Reply With Quote
Old December 22nd, 2006, 09:40 AM   #7
Just depends on what type of 'pipe' you get. You can run the gamut.
Since its just short pieces, you could go to the steel yard and get that stuff for free, I'd wager, from the garbage bin. Certainly could at my yard. I'd look for some 0.25" wall HREW, or sch 80 pipe.
Old December 22nd, 2006, 09:41 AM   #8
VonDirt
VonDirt's Avatar
a three point hitch is one thing - control arms are another. its just the wrong application thats all. they have incredibly poor tolerences in the joint itself, the threaded ones are way too coarse, not the right heat treatment - etc, etc.
however, their great to mock up different ideas or test things, just wouldnt run'em much beyond a test phase.
Old December 22nd, 2006, 09:43 AM   #9
fr3db3ar
KISS MY AVATAR
fr3db3ar's Avatar
Yeah.....the play in the joint is just incredible
Old December 22nd, 2006, 09:48 AM   #10
VonDirt
VonDirt's Avatar
very true - the yard would be a better place to start.
specifically the last pile next to the cast iron on the west side at Black River Recycling, (on chicago drive)
Old December 22nd, 2006, 09:54 AM   #11
VonDirt
VonDirt's Avatar
if you compare an FK or Ultimate from Canada to TSC . . . theres nothing to compare, other than there all called "hiems".
Old December 22nd, 2006, 10:08 AM   #12
greenmeanie
greenmeanie's Avatar
get a port city racing catalogue. (i think their site is portcityracing.com) they have tons of ends, and you can get the brand names and possibly buy from the company port city buys from.
greenmeanie is offline   Reply With Quote
Old December 22nd, 2006, 11:48 AM   #13
fr3db3ar
KISS MY AVATAR
fr3db3ar's Avatar
I'm going with bushings...they're just quieter
Old December 22nd, 2006, 12:12 PM   #14
Jeeperz Creeperz
GL 4x4 Vendors
Jeeperz Creeperz's Avatar
Isn't that the Rubicon Express Super Ride Retro Fit kit that you can get for $23.95?
Jeeperz Creeperz, Inc.
1627 Eureka Rd
Wyandotte, MI 48192
734-281-8141
M-F 10am-7pm
Sat 10am-3pm
www.jeeperz-creeperz.com
Old December 23rd, 2006, 01:25 AM   #15
dune coon
do work
dune coon's Avatar
I don't know, is it?
I just order stuff from polyperformance. They have other things that I need as well, so i just buy from them. 5 dollars difference?//
Page generated in 0.48246 seconds with 68 queries
