Recommended Gears - Great Lakes 4x4. The largest offroad forum in the Midwest
Old December 21st, 2006, 10:54 AM   #1
Weasal
Better than Newbie
Weasal's Avatar
Default Recommended Gears
Ive currently got 3.07's in my TJ with a 4.0 on 33's. Was running that for about a year and a half as my DD until the carrier recently busted and took some of the teeth with it.
I want to go to bigger gears but not sure if I should go up to 3.73 or 4.10. Just not sure how much it will kill me at highway speeds and what not, as I am usually driving an hour and a half on the e-way every other weekend.
Weasal is offline   Reply With Quote
Old December 21st, 2006, 11:00 AM   #2
PavementPounder
PavementPounder's Avatar
4.10 is generally considered ideal for 33's, but...
Is it an automatic or a manual?
If its an automatic, what year is it?
Old December 21st, 2006, 11:02 AM   #3
Weasal
Better than Newbie
Weasal's Avatar
manual
Old December 21st, 2006, 11:31 AM   #4
PavementPounder
I would say you'll be fine with 4.10's, unless you think your TJ will grow in the next year or so. That's a decent chunk of change to drop on the axles you have - you'll need a new front carrier also.
Old December 21st, 2006, 11:33 AM   #5
alexincj7
alexincj7's Avatar
4:10's will be ideal or if you want good MPG and good street use or maybe even 4:56's
alexincj7 is offline   Reply With Quote
Old December 21st, 2006, 11:35 AM   #6
greenmeanie
greenmeanie's Avatar
4:10's or 4:56's. i have some 4:56's for sale for a d-30 if you want to go that low. 4:10's should be enough for you w/ a 4.0 though.
greenmeanie is offline   Reply With Quote
Old December 21st, 2006, 11:38 AM   #7
Weasal
Better than Newbie
Weasal's Avatar
I dont think ill ever go bigger, but maybe i should maybe price out/figure out a way to do a dana 44 instead?
Old December 21st, 2006, 11:58 AM   #8
PavementPounder
If you're going to spend the money, that would be a better investment. The easiest way would be to find a TJ D44 rear, of course. You won't find one with factory 4.10's outside of a Rubi, but you can get a 3.73 and then only have to change the front gears. You might even be able to find a good used 3.73 front gearset & carrier to minimize the cost impact. 3.08 to 3.73 will feel a lot better, too.
Old December 21st, 2006, 12:03 PM   #9
Weasal
Better than Newbie
Weasal's Avatar
Do i just need to get lucky and find a classified/boards type sale for D44 or is there somewhere easier to find one?
Old December 21st, 2006, 12:03 PM   #10
DuffMan
Your Message Here
DuffMan's Avatar
I've got 4.56s with a 5-speed 4.0 TJ on 33s.
They're a little low for a DD - I turn 3000-ish RPM at highway speeds. Going from 3.07 to 4.10 will require new carriers F&R as PP stated.
4.56s are great on the trail. A wheeling buddy went to 4.10s with 33s and he's been quite happy as well - they would make for a better DD.
When I went from 3.07s (I ran them for about a year with 33s) to 4.56s, it felt like I dropped a hemi in there.
Another option is to go with a 8.8 rear axle instead of a D44 (it sounds like you've got a D35). 4.10 8.8s are fairly common, and make for a stronger axle to boot.
Old December 21st, 2006, 12:16 PM   #11
PavementPounder
Search Parts For Sale here on GL and also post an ad in the Wanted Forum. Be specific in your ad. Do the same on Misfits and other Jeep-related boards that are nearby, like GLJT. Also start cruising eBay.
The 8.8 is an option for you, but the added cost of having to fabricate the bracketry, buy a flange adapter, and possibly buy wheel spacers kind of defeats the purpose and would also not be a very quick solution. If you happened to find one that was already set up for a TJ, then I would consider it.
Page generated in 0.47312 seconds with 56 queries
