F-150 carbed/EFI engine combo - Great Lakes 4x4. The largest offroad forum in the Midwest
Old December 20th, 2006, 05:15 PM   #1
cjric
cjric's Avatar
Default F-150 carbed/EFI engine combo
I finished up swapping the new motor into my truck. I put a carbed block from a 77 with a EFI head/EFI from my 95. When dropping the motor in place, the oil pan hit the crossmember before the motor mounts hit the frame. Realized then that at some point they changed oil pan designs. I figure that when they went EFI they had to lower the engine so the intake would clear the hood. Or, for some reason they raised the crossmember.
So, if you ever put an old motor into a newer truck, make sure you use a newer oil pan.
cjric is offline   Reply With Quote
Page generated in 0.18548 seconds with 26 queries
