Fabricating wheels - Great Lakes 4x4. The largest offroad forum in the Midwest
Old December 20th, 2006, 05:26 PM   #1
Grandman
do i look old !
Grandman's Avatar
Default Fabricating wheels
Changing a back spacing .
These are rock crusher steel wheels , No one makes the back spacing i wanted so i changed these .
Welds are done on the inside of the wheel , using a common grinder i removed factory welds , careful not to cut into the wheel , the center section is much thicker where it welds to the outer section . Do most of the grinding there . They are a press fit but can be knocked out hitting the outer edge of the center section . While i left the tire mounted i did remove the air to be safe .
I have a snap on balancer i used to make sure i had the centers properly set before tacking them in with weld . After tack welding i placed them on the balancer once again to be sure they were true . I dont see why you couldn't do this on your rotor as well to check for trueness of the wheel .
Here is the wheel finished with my prefered back spacing and back on the Grand . Seems the welds are done on the back side there is no visible marks left on the wheel . This is a fairly simple project , take your time getting the center section true in the wheel . spin it on the rotor or a balancer if you can acess one . The only other thing is make sure you can make a quality weld or have the welding done by some one that is an experienced welder .
Old December 20th, 2006, 06:22 PM   #2
KILLER"B"468
Yankabilly
KILLER"B"468's Avatar
sweet!!!
Old December 20th, 2006, 06:35 PM   #3
FlamesFearMe
Custom User Title
FlamesFearMe's Avatar
That is cool. Nice Job!
FlamesFearMe is offline   Reply With Quote
Old December 20th, 2006, 10:52 PM   #4
nitrous nut
nitrous nut's Avatar
dumb ? if you put the center in backwards would it help to stop from poping a tire off the beed when wheeling?
nitrous nut is offline   Reply With Quote
Old December 20th, 2006, 11:05 PM   #5
Then you will pop the inner beads. You can buy reversed rims like that, but I'd rather blow the outer bead myself.
G-man, what did you set the backspacing to? Or in general, how much did you move? Are you wider or narrower now?
Old December 21st, 2006, 09:00 AM   #6
Grandman
do i look old !
Grandman's Avatar
I reduced the back spacing by 1 " , thats the most the wheel would allow they way it is built .
Adapters on the 8.8 to 5 on 5.5 pattern left we wide in the back so customized the front wheels to match width .
I looked at 1.25" spacers but they were $249.00 This took a few sticks of welding rod and about 3 hours . A gain of 2" total width should stablize the Grand a little as well .
Old December 21st, 2006, 09:29 AM   #7
roll-bar Bob
roll-bar Bob's Avatar
Good Work
Old December 21st, 2006, 03:24 PM   #8
clarkstoncracker
lol
clarkstoncracker's Avatar
Thats pretty sweet.
Any vibrations now?
Old December 21st, 2006, 03:41 PM   #9
Grandman
do i look old !
Grandman's Avatar
Thats pretty sweet.
Any vibrations now?
Yes but they were there before the wheel work . I think it's mostly the Bias tires im feeling . These Q 78 tires have been a real PITA to balance since i got them as well . I can roll down the road 60 - 70 mph when needed but the Grand is not as road friendly as it use to be .
Im tempted to put the 34x12.50 Trxus on another set of wheels i have just to see the difference it makes .
Old December 21st, 2006, 05:51 PM   #10
Icebreaker88
Icebreaker88's Avatar
Nice job Marv
Must be nice having all that time on your hands now
[QUOTE=TurdBronco;1095911]I don't usually race cause it is still a focus.[/QUOTE]
Icebreaker88 is offline   Reply With Quote
Old December 30th, 2006, 12:15 PM   #11
sglide
co captain of cubes pants
sglide's Avatar
sglide is offline   Reply With Quote
Old December 30th, 2006, 02:38 PM   #12
Bones
Bones's Avatar
Did you ever put the rim on the balancer without the tire? I would be interested how balanced just the rim is...
good work though.
Inviscid Motorsports
Motorcity Machines
Branik Motorsports
Maxxis Tires
Raceline Wheels
PAC Racing Springs
Joint Clutch and Gear
Old December 30th, 2006, 02:45 PM   #13
Cooter
Dad Kickin' It OldSkool
Cooter's Avatar
That's the old school way of "reversing" wheels- works great. (Usually the bucks down guys just mount the wheel on the spindle to make sure it is centered and true)
Glad to see it is still being done.
Page generated in 0.30685 seconds with 62 queries
