Remote Start - Great Lakes 4x4. The largest offroad forum in the Midwest
Old December 20th, 2006, 04:03 PM   #1
Tie Dyed
O.G.
Tie Dyed's Avatar
Send a message via AIM to Tie Dyed
Default Remote Start
Why do you think they would tell you not to use one of those splice connectors?? They would make it so much easier.
2000 XJ with a 3 inch body lift
Tie Dyed is offline   Reply With Quote
Old December 20th, 2006, 04:04 PM   #2
nate4d
Gnarley Davidson
nate4d's Avatar
Send a message via AIM to nate4d
moisture.
nate4d is offline   Reply With Quote
Old December 20th, 2006, 04:08 PM   #3
Tie Dyed
O.G.
Tie Dyed's Avatar
Originally Posted by nate4d View Post
moisture.
What if I taped it?
Old December 20th, 2006, 04:27 PM   #4
purplejeep
Oldbie
purplejeep's Avatar
Originally Posted by Tie Dyed View Post
What if I taped it?
It would be good for an extra week.
purplejeep is offline   Reply With Quote
Old December 20th, 2006, 05:36 PM   #5
greenmeanie
greenmeanie's Avatar
soldering and heat shrink makes it permanent and waterproof
greenmeanie is offline   Reply With Quote
Old December 20th, 2006, 05:50 PM   #6
pyrowaves
The Boss
pyrowaves's Avatar
Send a message via AIM to pyrowaves
any kind of crimp on splice conn or scotch lock sucks wouldnt use them inside or out.. might as well do it right with solder and heatshrink. they make nice heat shrink with glue in it that makes it totally waterproof.or heatshrink without.
pyrowaves is offline   Reply With Quote
Old December 20th, 2006, 05:56 PM   #7
GreaseMonkey
Pew pew!
GreaseMonkey's Avatar
Make sure it's waterproof and done correctly. I had a few vehicles come into the shop over the summer that had no-start conditions and were blowing fuses.
Both vehicles had a fried remote start module, so I disconnected the system and took care of the problem. Whoever had done both vehicles just wrapped wires and taped them.
P.S.: NAPA has nice solderless heatshrink connectors.
Old December 21st, 2006, 11:32 PM   #8
Buggy_Tim
(513) 891-8372
Buggy_Tim's Avatar
Yea...I have seen so many vehicles come in with no starts because of the little blue line tap things...scotch locks as they are called. They suck.
I have remote start in all my vehicles, and put it in my mother in laws car too. ALl soldered and heat shrinked. I did one in a 98 escort that my mother in law bought brand new. She sold it to us, we just sold it last year...had 196,000 miles on it and the remote start still worked fine and never had any trouble out of it.
Solder is the only way to go. Don't be lazy young Jedi learner...
Old December 22nd, 2006, 07:29 AM   #9
clarkstoncracker
lol
clarkstoncracker's Avatar
There are new connectors that clip around the existing wire, and cut into it to make connection to the new wire without the need to cut and solder. They are rated for 15 amps/600V
They are UL listed for AC in wet locations, and they are filled with epoxy. When you press the button down it busts the package all over your connection.
If you need some, let me know, they are $6.40 per
If anybody tells you to solder a wire on a car today, they are stuck in the 70's.
Don't use electrical tape for insulation on anything. even though it looks protected, it doesn't do anything.
Old December 22nd, 2006, 09:54 AM   #10
Hacksaw
WWSD - What would stan do
Hacksaw's Avatar
hahahahahahh
Old December 22nd, 2006, 09:56 AM   #11
junk90xj
ALLPRO AUTO
junk90xj's Avatar
i disagree. if a vehicle comes in my shop i will not do wire repair unless its solder and wrap. i hate comebacks and wont chance it on a stupid connection.
http://www.apalansing.com/
Old December 22nd, 2006, 10:59 AM   #12
GreaseMonkey
Pew pew!
I've used the solderless shrink wrap things from NAPA. A heat gun will melt the solder in the connector which makes them quick and easy to use.
Old December 23rd, 2006, 02:28 PM   #13
frdboy
frdboy's Avatar
I to have seen way too many problems come in from remote starters with scotch-lock connectors, I use uninsulated, crimp connectors with heat shrink. Soldiering can make wiring brittle and break so I avoid that unless necessary.
Adam
Old December 24th, 2006, 12:19 AM   #14
Buggy_Tim
(513) 891-8372
Buggy_Tim's Avatar
or they don't want to spend 100 bucks in fancy scotch locks. Those things might be great for the work you do...but you don't see them in the local napa store.
I could just see telling a customer: "Yea, i'm gonna install this 69.99 remote start for you, but I have to buy 20 of these special scotch locks so it'll be an extra 128 bucks in electrical connectors."
Old December 24th, 2006, 12:21 PM   #15
jared
Can't Worry About It
jared's Avatar
well if any of you decie to go out and become and aviation airframe and powerplant tech, you don't solder wires unless they are a temporary repair. solder makes the connection stiff and it can work harden the wires causeing them to break. a spliced connecton is a faa certified repair (meaning the aircrafts you fly on use them) and they are done very well. dual crimped, have a anti corrosion compound in them like clarkston cracker posted, and are sealed in heat shrink tubing for even more protection. so i use both in my vehicle, solder and crimp on connectors. i usually will solder wiring and heat shrink if its on the ouside of my vehicle just in case because i don't buy the expensive connectors like the aviation world uses. but crimp on connectors are ok in my book if they are done properly.
oh and i am almost a licensed A&P mechanic just have 2 more tests to take.
jared is offline   Reply With Quote
Old December 24th, 2006, 06:51 PM   #16
Buggy_Tim
(513) 891-8372
Buggy_Tim's Avatar
Wait...
<looking around>
Ok, hang on for a sec....
<peeking around a little more>
Yea, ok, whoa, wait a sec....
<checking a few more things>
Yup...I am perdy sure we are not talking about giant ass generators, 600 volts, or airplanes. We're talking about a car that will see salt.
Also, in the Navy, before you can advance from AT1 (first rate) to AT2 (second rate) you have to perform job B435 SOLDER CONNECTIONS. This is for Avations Electronics Technician. It's in chapter 11 of the book.
Old December 28th, 2006, 10:13 PM   #17
BILL C.
** TEAM KAMIKAZE 4X4 **
BILL C.'s Avatar
at the bare minimum soldier the heavy gauge wires. these are the high current wires and are the biggest ones on the remote start unit. if you wanna use t taps for some hard to reach brake wires everything will be fine as long as you crimp it good. if you can soldier everything than better yet.
BILL C. is offline   Reply With Quote
Page generated in 0.37404 seconds with 74 queries
