Corp 10 bolt front - Great Lakes 4x4. The largest offroad forum in the Midwest
Old December 18th, 2006, 02:21 PM   #1
Ebrown
Ebrown's Avatar
Default Corp 10 bolt front
I just bought a corp 10 bolt front. Here the problem, Where the steering arm mounts to the knuckle I'm trying to remove the 3 studs and replace with new, While I was trying to remove one of them snapped one of the off flush to the top of the knuckle. How do I remove it? and how do I get the other two out with out snapping them off two.
Ebrown is offline   Reply With Quote
Old December 19th, 2006, 10:08 AM   #2
bigblazer
ditch digger
To get the broken one out you'll probably have to drill it and use a easy out. You can probably try putting a little heat on them to. For the ones still in clamp some vise grips on them if you dont plan on reusing the studs or use a stud puller. Did you get the conical washer out and the steering arm off?
bigblazer is offline   Reply With Quote
Old December 19th, 2006, 04:41 PM   #3
Ebrown
Ebrown's Avatar
I have new studs, Conical, and steering arm.
Page generated in 0.32633 seconds with 32 queries
