76 Dana 44 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old December 17th, 2006, 02:13 PM   #1
cjaholic
(o )( o)
cjaholic's Avatar
Question 76 Dana 44
I just bought a set of axles, 44/14, from a 76 chevy. The Dana 44 has the dual flat-top knuckles, and HUGE hubs by spicer. When I say HUGE I mean about 4-5" in dia. Is there any real benifet to having the large hubs, are they any stronger than the smaller 44 3/4 ton hub?
cjaholic is offline   Reply With Quote
Old December 17th, 2006, 07:15 PM   #2
cjaholic
(o )( o)
cjaholic's Avatar
What are the odds that this is a ball joint 60. After looking around I see that the 60 has a 4" hub. My lockouts look alot like this one. Do the ball joint 60's have knuckles that look like a 44? Also the short side of the axle is real short about 8-10". Anyone have pics of a dana 60 with ball joints?
Old December 17th, 2006, 07:42 PM   #3
PavementPounder
PavementPounder's Avatar
If its a D60, it will have a "60" cast into the diff. See it at the lower right?
Old December 17th, 2006, 07:47 PM   #4
Ebs
Is it a driver side differential? Probably not since they were in a Chevy, but I don't think GM ever used a balljoint 60.
Sure they're not just the big external hubs that came on some D44s.
Old December 17th, 2006, 09:17 PM   #5
cjaholic
(o )( o)
cjaholic's Avatar
Well, its not a 60, the tubes are too small. Guess I didn't get that lucky. Are the big hubs good? Spline?
Old December 17th, 2006, 09:25 PM   #6
95geo
newbie
95geo's Avatar
sounds like an 8 lug 44.... they taper down to a 44 hub, the 60 is straight and the smaller bolt pattern 44 hubs are straight.
Old December 17th, 2006, 09:46 PM   #7
bigblazer
ditch digger
Ya a big hub 44, Just make sure you keep the bolts tight cause they like to back out. The lock outs are more expensive to if you break one, the stubs are the same as all other 44s to.
bigblazer is offline   Reply With Quote
Old December 18th, 2006, 10:34 AM   #8
cjaholic
(o )( o)
cjaholic's Avatar
So is there any reason to keep the big hubs? I have a couple more axles I could rob some hubs off of. Are they any stronger?
Old December 18th, 2006, 12:30 PM   #9
PavementPounder
I would imagine bigger bearings.
Old December 19th, 2006, 03:14 PM   #10
cjaholic
(o )( o)
cjaholic's Avatar
Here is a pic.
Name:	for sale 004.jpg
Old December 19th, 2006, 09:34 PM   #11
PavementPounder
What's that ring around the hub?
And why is the word "contraption" suddenly popping into my head?
Old December 19th, 2006, 09:51 PM   #12
cjaholic
(o )( o)
cjaholic's Avatar
I don't know, it looks like some kind of gasket, its on both sides.
Old December 20th, 2006, 01:38 PM   #13
bigblazer
ditch digger
If you can see in the pic the hub is a lot shorter for the external drive flang. Yours probably had flanges and was converted to lockouts at some time. So the ring is a seal for the extension.
Old December 20th, 2006, 03:56 PM   #14
cjaholic
(o )( o)
cjaholic's Avatar
Check this out!! WTF does this mean? If you can't read that, it's 44-5CF
Old December 20th, 2006, 04:09 PM   #15
PavementPounder
Helloooooo? Google?
http://tamor.org/forums/printthread.php?t=7928
http://coloradok5.com/forums/archive...p/t-77796.html
http://www.fullsizechevy.com/forums/.../t-208497.html
Its apparently just the casting number for the center section.
Old December 20th, 2006, 04:48 PM   #16
cjaholic
(o )( o)
cjaholic's Avatar
Alright smartass
You make it to easy to be lazy around here.
Page generated in 0.36163 seconds with 72 queries
