Q: Flat towing a TJ, does anyone make a addon tow brake? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old December 15th, 2006, 02:15 PM   #1
Smiley
Smiley's Avatar
Default Q: Flat towing a TJ, does anyone make a addon tow brake?
I'm thinking about selling my flatbed trailer and just flat towing my TJ. But to be legal (and safe) the towed vehicle is supposed to have some kind of break-away brake system. Does anyone make such an addon brake system that also could be used with the towing vehicle's brake controller to aid when braking in general?
Smiley is offline   Reply With Quote
Old December 15th, 2006, 02:42 PM   #2
Smiley
Smiley's Avatar
Found some from BrakeBuddy and BlueOx.
Does anyone have experience with any of these products?
Old December 15th, 2006, 09:09 PM   #3
Blackjackbender
you may have better luck on a RV board or something.
Old December 15th, 2006, 10:34 PM   #4
scottie
Eye candy
scottie's Avatar
i didn't think Michigan required the brake
Old December 16th, 2006, 02:32 AM   #5
Mclovin
"The Situation"
Mclovin's Avatar
x2
Never heard of a vehical being flat towed needing brakes.. ?
Old December 16th, 2006, 09:04 AM   #6
nmeinc
Parts Galore Spokesmodel
nmeinc's Avatar
why bother towing it at all? if you break, IE: tire, axle, trans it's gonna suck to flat tow. and if you have a smaller spare on flat towing is out.
nmeinc is offline   Reply With Quote
Old December 16th, 2006, 09:11 AM   #7
Bleay
sick of jackstand wheelin
Bleay's Avatar
x2 if you break a axle very common on a d35 (if thats what you have) how are you going to flat tow it with 3 wheels. If it's an automatic you need to remove your rear driveshaft.
i have used both tow bars and trailers and would recommend sticking with the trailer.
Bleay is offline   Reply With Quote
Old December 16th, 2006, 11:27 AM   #8
Buggy_Tim
(513) 891-8372
Buggy_Tim's Avatar
Not true.
Onlt have to pull driveshafts if he is locked front and rear.
Old December 16th, 2006, 11:50 AM   #9
Bleay
Bleay's Avatar
Originally Posted by MuddyPaws View Post
Not true.
well if it was mine and it was an auto i would pull the rear driveshaft. for the few minutes of work it's better to be safe than sorry
Old December 16th, 2006, 12:46 PM   #10
Buggy_Tim
(513) 891-8372
Buggy_Tim's Avatar
Ever read the owner's manual? Says put it in park, shift tcase to neutral, flat tow.
What's not to be safe there? Automatic can't turn in park. Even with a manual you are supposed to put it in gear with the tcase in neutral.
Old December 22nd, 2006, 06:43 PM   #11
Mijeeper CJ 7
Mijeeper CJ 7's Avatar
True. I flat towed my 98 TJ behind my motorhome for over 15,000 mile and never had any trouble. I never pulled the driveshaft.
Mijeeper CJ 7 is offline   Reply With Quote
Old December 22nd, 2006, 08:53 PM   #12
lgottler
lgottler's Avatar
I've only towed mine a total of 30 miles, just put the trans in gear, t-case in neutral and unlocked the steering column....
lgottler is offline   Reply With Quote
Old January 4th, 2007, 07:45 AM   #13
SHARPMACHINE
F-U-CANCER!!!
SHARPMACHINE's Avatar
My father flat towes his ford sport-trac behind his motorhome. He uses one of those brake units, and likes it. He has pulled it with and without and it works good. One bonus is, if the vehicle comes unhooked, the brakes are supposed to be applied.
RIP FULLSIZE4LIFE
Old January 4th, 2007, 09:41 AM   #14
Mongo
Mongo's Avatar
BlueOx is a nice unit. I know of 3 people that use it and all are happy.
Mongo is offline   Reply With Quote
Old January 4th, 2007, 10:24 AM   #15
Bones
Bones's Avatar
Almost any vehicle made in the last 10 years can be flat-towed safely without removing driveshafts, just look in the owners manual. RVing makes up a big enough portion of potential customers that it is worth the time to engineer the powertrain to be flat towed.
Inviscid Motorsports
Motorcity Machines
Branik Motorsports
Maxxis Tires
Raceline Wheels
PAC Racing Springs
Joint Clutch and Gear
Old January 5th, 2007, 06:57 PM   #16
Viperdave
A-1 Dave Costa
Send a message via AIM to Viperdave
Very few 2wd automatics can be flat towed, saturn is one of the few...
On to 4wd, anything with a tcase can be flat towed... put it in neutral...
In terms of the brake system, some of the people we camp with use blueox and have had excellent luck. If you pick up a recent copy of motorhome magazine, there are several units in it that work. Also later tonite, i will pull out my motorhome tow guide, it most likely lists brake assist units in it...
Viperdave is offline   Reply With Quote
Page generated in 0.34341 seconds with 71 queries
