Mig 110 or 220 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old December 14th, 2006, 11:51 AM   #1
BowtieWrangler
BowtieWrangler's Avatar
Default Mig 110 or 220
when welding(mig) shock mounts and track arm mounts, can you use 110volt welder rated to weld the thickness of material or do i need to use the 220 due to the fact it gets hotter?
this is for an 8.8 in my YJ i just wanna make sure before it gets welded up
BowtieWrangler is offline   Reply With Quote
Old December 14th, 2006, 12:09 PM   #2
110v would work for those applications. Clean everything very good to bare clean metal, make sure the parts fit tightly, and bevel the edges a bit to get better penetration.
Old December 14th, 2006, 01:15 PM   #3
junk90xj
ALLPRO AUTO
junk90xj's Avatar
110v would work for those applications. Clean everything very good to bare clean, make sure the parts fit tightly, and bevel the edges a bit to get better penetration.
perfectly put.
http://www.apalansing.com/
Old December 14th, 2006, 03:19 PM   #4
BowtieWrangler
thank you
Page generated in 0.19135 seconds with 35 queries
