Wheel adapters - Great Lakes 4x4. The largest offroad forum in the Midwest
Old December 12th, 2006, 01:59 PM   #1
greenmeanie
greenmeanie's Avatar
Default Wheel adapters
can anyone make these? i am looking for 5.5in to 4.5 in adapters. probably need to be 1 inch thick for strength/ stud mounting. how much $$$ for 2 if possible to make? thanks.
greenmeanie is offline   Reply With Quote
Old December 12th, 2006, 02:28 PM   #2
fr3db3ar
KISS MY AVATAR
fr3db3ar's Avatar
I would just do a google search. They can be had for around $40 each
Old December 12th, 2006, 03:27 PM   #3
greenmeanie
i can't find any that make the spacing smaller, only bigger
Old December 12th, 2006, 04:19 PM   #4
Have you looked into the ther details. For example, can you fit the adapter or actual wheels around the wheel hub or axle shaft outer size? That might be a big factor.
Old December 12th, 2006, 07:28 PM   #5
greenmeanie
everything will fit into the wheel; just want to use my rims i already have. i just bought a d-44, which is a different bp than my wheels. they were a gift and they match, so i want to still use them w/ the new axle
Old December 13th, 2006, 06:46 AM   #6
fr3db3ar
KISS MY AVATAR
fr3db3ar's Avatar
Here's the first one I found with a 5 minutes search for wheel adapters
http://www.adaptitusa.com/index.asp?...PROD&ProdID=61
Old December 13th, 2006, 07:01 AM   #7
Bleay
sick of jackstand wheelin
Bleay's Avatar
You are probably just going to have to live with a wider wheelbase or spend the money on new axle shafts.
Bleay is offline   Reply With Quote
Old December 13th, 2006, 07:02 AM   #8
VonDirt
VonDirt's Avatar
i can make'm but they would be more expensive than you could just buy some for. like fr3db3ar said, i think theres all kinds of options out there.
VonDirt is offline   Reply With Quote
Old December 13th, 2006, 09:55 AM   #9
greenmeanie
i found one company who makes them. wheeladapterz.com if anyone else needs any; ezaccessory.com was another. i figured it would be more expensive to have someone make them, but i was having a hard time finding the ones i needed. thanks for the input guys
Old December 13th, 2006, 08:10 PM   #10
Tonka
Tonka's Avatar
What is the 44 out of ?
you may be able to swap axleshafts and brakes with a tj or early xj 44 (rears) to get your bolt pattern.
Old December 13th, 2006, 10:11 PM   #11
greenmeanie
it's out of a cj. i think i am going to weld on some gm brackets for disk brakes
Page generated in 0.23986 seconds with 56 queries
