will rubi coils give an xj a lift? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old January 3rd, 2006, 08:35 PM   #1
mrclean
Silver Lake
mrclean's Avatar
Default will rubi coils give an xj a lift?
I didn't know if I used a set of rubi coils in front on my 98 xj, will it give it any type of lift? Of course I know I would have to have my rear leafs re-arched to match, just curious about doing a cheap lift on the front.
mrclean is offline   Reply With Quote
Old January 3rd, 2006, 08:44 PM   #2
$500 MJ
MJ conosuer
$500 MJ's Avatar
Send a message via MSN to $500 MJ
Add a leafs work fine in the rear and usually will take less time to install rather than rearching your leafs and all. I had a spring shop make me mine from some stock leafs from a some truck (Idk which one, grabbed spring packs from a pile). When you separate the spring packs use C clamps. I can swap my leafs in and out in about 15 mins.
No clue on the Rubi coils, just thought I'd share some knowledge.
$500 MJ is offline   Reply With Quote
Old January 3rd, 2006, 08:50 PM   #3
PavementPounder
PavementPounder's Avatar
I have some stock XJ coils out of the XJ right now if you want to compare them to some Rubi coils.
Old January 3rd, 2006, 08:59 PM   #4
mrclean
Silver Lake
mrclean's Avatar
thanks for the info on the leafs, I'll add-a-leaf instead. As far as comparing the coils, I might take you up on that pp.
Old January 3rd, 2006, 09:39 PM   #5
amc78cj7
amc78cj7's Avatar
I have a pair of stock XJ coils you can have free for your comparison. Spro has to take them with him tomorrow though. I want them out of my garage.
amc78cj7 is offline   Reply With Quote
Old January 3rd, 2006, 10:26 PM   #6
nixxerRsixxer
Homewrecker
nixxerRsixxer's Avatar
TJ coils are shorter than XJ coils.. so no lift..
The 129/130 coils found on the Rubi/Sahara/Sport/Unlimited are the same..
nixxerRsixxer is offline   Reply With Quote
Old January 3rd, 2006, 10:30 PM   #7
Roadhouse
DrivewayJeeper
Roadhouse's Avatar
I know a ZJ front coil in you're XJ will give you about 1" of lift.
But sorry I threw all mine away.
Old January 4th, 2006, 06:23 AM   #8
mrclean
Silver Lake
mrclean's Avatar
that's kind of what I thought. Just thought I would ask before doing. What about putting an 1.75" puck in front and then lifting the rear? Could I fit 31's with an offset wheel?
Old January 4th, 2006, 08:08 AM   #9
Jeeperz Creeperz
GL 4x4 Vendors
Jeeperz Creeperz's Avatar
A coil spacer and shackle lift will give you enough room to fit 30x9.50. To fit 31's you'll need 3" (depending on the year of the XJ).
Unless you're willing to trim....
Old January 4th, 2006, 09:03 AM   #10
amc78cj7
amc78cj7's Avatar
We added a Rustys 3" lift to our XJ to fit 31s. It was fairly cheap and came with an add-a-leaf and new front coils and shocks for under $245. Some people don't like Rustys though because sometimes deliveries are not very prompt. I find this to be status quoa in Jeep parts though (except the big distributors like 4wdh), so I just deal with it and know I will have a nice rig when I'm done. Just giving you a fore-warning so we don't see 20 posts about how "bad" Rustys is. Here is a link.
https://rustysoffroad.com/Merchant2/...ode=sus_xj_kit
Old January 4th, 2006, 01:12 PM   #11
PavementPounder
31's + OEM backspacking + 6" lift on a 98 XJ = rubbing on the rear swaybar on relatively low compression (turning into inclined driveways, etc). 30's will most likely hit it also with only a 3" lift. Remove the sway bay or get wheels with less backspacing.
Old January 4th, 2006, 01:14 PM   #12
PavementPounder
Just do it.
http://greatlakes4x4.com/showthread.php?t=2025
Old January 4th, 2006, 01:28 PM   #13
mrclean
Silver Lake
mrclean's Avatar
I ran a 3" BDS on a 97 xj I had and it cleared the 31's just fine. I used a stock wheel and had minimal rubbing at full turn. Only thing I didn't like was the ride (wife complained about it). I might try the Rusty's, $245 with shocks seems like a damn good deal. Pavement Pounder, I would run the 6" but this is her dd and I promissed I wouldn't go to extreme. Yours looks good though, just get some new meats.
Old January 4th, 2006, 01:53 PM   #14
PavementPounder
I'm not talking about rubbing LCA's at all, but mine barely touches them just like your old one does.
I'm talking about the rear tire going up into the fender and hitting the rear sway bar when running OEM rims with 4" of backspacing. I have a 6" lift with 31x10.5's and I still hit the sway bar hard when turning into parking lots or driveways that have a raised entrance. What I'm saying is that even with a 1" smaller tire, the fact that you will have 3" less lift will make the situation worse on yours than on mine in the rear if you intend to use our OEM rims and not remove the sway bar (like I am going to).
I just bought the 31's because I knew they would still rub with a 6" lift and no trimming on an OEM rim. Anything bigger and I'd start tearing off pieces of tire. Wheels with less backspacing would fix the swaybar problem, but a larger tire on a wheel with less backspacing would then start bashing the factory flares. I think FrankNBrew is running 33's now on his XJ and he had to add more lift than me and do a lot of trimming. Think he said he still rubs.
Old January 4th, 2006, 02:04 PM   #15
Lothos
KD8GKB
Lothos's Avatar
Rubi springs are of stiffer design than comparable TJ springs. They may be the same length, but TJ's using Rubi springs have yielded 1 inch in lift.
Old January 4th, 2006, 02:05 PM   #16
mrclean
Silver Lake
mrclean's Avatar
I'm going to change to aftermarket rims with less backspacing anyways. I'm not all that concerned with hitting in the wheel wells because I doubt this thing will ever see the trail or full flex.
Old January 4th, 2006, 02:24 PM   #17
nixxerRsixxer
Homewrecker
sorry no.. the 129 and 130 Pn# found on Rubis is also found on Saharas/Sports/Unlimiteds..
Old January 6th, 2006, 01:28 AM   #18
PavementPounder
Okay, and its good that you are going to get less backspacing, but I never said anything about hitting any wheelwells. The problem back there is the swaybar, swaybar, swaybar, swaybar, swaybar, swaybar.
Did I mention I was talking about the rear swaybar?:tonka:
Old January 6th, 2006, 09:04 AM   #19
mrclean
Silver Lake
mrclean's Avatar
wow, never had a problem before, don't see myself having a problem now.
Old January 6th, 2006, 10:30 AM   #20
Lothos
KD8GKB
Lothos's Avatar
That must have changed after the 2003 model then. Every Rubi owner that year tried the spring swap from their rubi's to other TJ's and got 1 inch of lift.
Page generated in 1.19809 seconds with 83 queries
