Dana 30 stock spline vs 30 spline - Great Lakes 4x4. The largest offroad forum in the Midwest
Old December 11th, 2006, 06:33 PM   #1
Cube
Captain of my pants
Cube's Avatar
Default Dana 30 stock spline vs 30 spline
So I am going to order a ox locker for my front 30. And I was deciding if I want to go with a stock spline count or up to to a 30 and get new shafts. I would buy front alloy shafts. Now is it worth it? Should I just keep stock cause shafts are dime dozen and I wouldnt be gaining much strenth? I run boggers 35X14.5X15
Cube is offline   Reply With Quote
Old December 11th, 2006, 06:35 PM   #2
PavementPounder
PavementPounder's Avatar
I think you're going to break stuff no matter what you do. You may not break shafts, but I think you'll break other shit after owning that CJ. You'll have your foot in it all the time. :tonka:
I have a free HPD44 housing available. Come get it and build one like Grandman.
Old December 11th, 2006, 07:07 PM   #3
Cooter
Dad Kickin' It OldSkool
Cooter's Avatar
Keep it stock- I did, and still haven't hurt an axleshaft in the D30
Old December 11th, 2006, 07:33 PM   #4
Cube
Captain of my pants
Cube's Avatar
cooter, what tires and were/are you locked?
Old December 11th, 2006, 07:46 PM   #5
Cooter
Cooter's Avatar
35x14.50 Boggers and Q78 Swampers since '02, locked in the D30/Spooled 8 3/4 rear.
Old December 11th, 2006, 08:14 PM   #6
Noah's Ark
Noah's Ark's Avatar
Obviously never seen cube drive!
Noah's Ark is offline   Reply With Quote
Old December 11th, 2006, 08:18 PM   #7
Cooter
Cooter's Avatar
Still better to see what he breaks in the D30 first before he spends a lot of money on it. If he upgrades the spline count, he will be breaking R&Ps and carriers instead of axleshafts.
Old December 11th, 2006, 08:49 PM   #8
Cube
Captain of my pants
Cube's Avatar
hhaha but I want to get a locker for it, hmm 27 or 30 or just go with a 44 front hmmmmmmm what to do. I just dont want to put alot of money in a 30 if I am going to be needing a 44 but I heard good things about the 30s hmmmmm
Old December 11th, 2006, 08:53 PM   #9
Cooter
Cooter's Avatar
Toss a used LockRight in it, and see how it holds up.
Old December 11th, 2006, 11:00 PM   #10
Grandman
do i look old !
Grandman's Avatar
I dont know what this is in John ? If it is 4.0L power and an auto trans i think the 30 can survive . If its V8 power forget it . Larger then 33" tires will put the hurt on it . Cooter is running a fairly light weight rig , that comes into play as well . My Grand sits at damn near 5,000 lb and the 30 was killing stock shafts 2 or 3 to a run .
Old December 12th, 2006, 05:16 AM   #11
Cube
Captain of my pants
Cube's Avatar
its for my TJ with 4.0L and 35x14.5 boggers so heavy tires
Old December 12th, 2006, 09:52 AM   #12
Grandman
do i look old !
Grandman's Avatar
I dont see it surving 35 boggers , boggers are death in a form or rubber
Old December 12th, 2006, 10:44 AM   #13
Monkeyevil
I <3 Miatas
Monkeyevil's Avatar
44's are going to have the same balljoints, and u-joints. They are a little beefier in the yokes, and obviously 30 spline.
I dunno what I would do... I guess I would price the 30 spline OX and the shaft price difference.
JcrOffroad
Zoom Zoom!
Old December 12th, 2006, 10:53 AM   #14
4-PLAY
4-PLAY's Avatar
Mine are holding up fine-warn shafts
Mud=ok
sand=ok
Rocks=no way
arb with 35" ssr and boggers
4-PLAY is offline   Reply With Quote
Old December 12th, 2006, 10:03 PM   #15
Cube
Captain of my pants
Cube's Avatar
well the ox 30 and 27 spline are the same so its a wash there, I can alloy shafts with u joints and everything for 540, alot cheaper than a swap and should be just as strong right?
Old December 12th, 2006, 10:46 PM   #16
Jeepaholic
Axle Guru Extraordinaire
Jeepaholic's Avatar
Another good option for alittle more strength in the r&p is getting a hp30 from an xj.
Page generated in 0.34114 seconds with 71 queries
