New Dodge Ram Cummins or MDS Hemi - Great Lakes 4x4. The largest offroad forum in the Midwest
Old December 11th, 2006, 01:18 AM   #1
BowtieWrangler
BowtieWrangler's Avatar
Default New Dodge Ram Cummins or MDS Hemi
Im gonna be picking up a new ram in the spring and i was interested in knowing the mileage of the Cummins both city and highway....and if you know about the towing mileage taht would be helpful (ill be towin bout 4-5 thousand pds)
im tryin to compare it between the multidisplacement hemi because i was set on getting the Hemi but i didnt know if the diesel was more worth while and maybe if the mileage would be better?
i guess i should add it would be an extended cab, 4x4, with the new 5speed Automatic Trans(Hemi) or 4speed Auto(Cummins)
BowtieWrangler is offline   Reply With Quote
Old December 11th, 2006, 01:40 AM   #2
Mclovin
"The Situation"
Mclovin's Avatar
if you're gona be towing 5k lbs plus your trailer, Id spring for a cummins IF you can afford.
Old December 11th, 2006, 05:56 AM   #3
PavementPounder
PavementPounder's Avatar
1. Buy the CTD. Although the Hemi will get the job done, you will be very disappointed with the mileage.
2. By the time you're ready to buy, the 68RFE 6-speed automatics will be out behind the CTD's and will be rated 40hp over the other drivetrains. (350/650 vs 350/610).
Old December 11th, 2006, 06:44 AM   #4
roll-bar Bob
roll-bar Bob's Avatar
CTD !!!! IF YOU CAN SPRING FOR IT I WILL NEVER GO BACK TO GAS
Old December 11th, 2006, 08:00 AM   #5
PavementPounder
Yeah, you can't beat how they flex. :tonka:
Old December 11th, 2006, 09:05 AM   #6
TopHeavy
Yikes!
TopHeavy's Avatar
I have a 2006 CTD 4x4. I am getting about 17mpg with about 90% city driving. I have spent MANY hours behind the wheel of an MDS Hemi ram. Buy the CTD. The only time I would get the Hemi in a 2500 is in the Power Wagon but that is the only engine available. As a side note: I have wheeled the Power Wagon at the Mounds and in Moab. It is a very capable rig. Something else to consider.
Buy My CJ7
TopHeavy is offline   Reply With Quote
Old December 11th, 2006, 02:38 PM   #7
dline
dline's Avatar
the MDS hemi ram does do better than a non MDS engine, the MDS is only available in a 1/2 ton. you can get 20mpg @ 70 mph with an MDS.
the diesel will have that new 6 speed auto also.
dline is offline   Reply With Quote
Old December 11th, 2006, 02:39 PM   #8
PavementPounder
Thanks, I didn't think anyone was going to believe me.
Old December 11th, 2006, 02:44 PM   #9
dline
dline's Avatar
your welcome.
Old December 11th, 2006, 03:17 PM   #10
TopHeavy
Yikes!
TopHeavy's Avatar
I believed you. But then again I have actually driven it.
I wish mine had the 6 speed.
Buy My CJ7
Old December 11th, 2006, 03:53 PM   #11
BowtieWrangler
i originally posted about the 6speed and changed it becuase i thought u guys would think i was an idiot. So that CTD sees equally good mileage, i do not really plan on wheeling this thing, more of a DD and tow rig to pull my wrangler........thanks for the input more to consider
Old December 11th, 2006, 03:56 PM   #12
user name
keep your stick onthe ice
user name's Avatar
the CTD really holds its value if you can afford it in the begining
Old December 11th, 2006, 05:23 PM   #13
Yetti
Buy a Fiat! Save the UAW!
Yetti's Avatar
if your ready to buy theres a `06 2500 mega cab 4x4 w ctd & 6spd manuel sitting on Village motor sales lot right now. if you get employee discount then add that & the $5500 rebate and its good deal for that truck.
Yetti
Old December 11th, 2006, 05:59 PM   #14
PavementPounder
I was being sarcastic since he ed the same info I put up just a few posts prior.
Old December 11th, 2006, 06:00 PM   #15
dline
dline's Avatar
:chiefwoohaw:
Old December 11th, 2006, 06:03 PM   #16
Viperdave
A-1 Dave Costa
Send a message via AIM to Viperdave
we took a 2005 CTD quad cab dually 4wd 6spd 4.10 gears on a 2000 miles trip towing a 6k lb trailer. Averaged 63mph and 18mpg
Viperdave is offline   Reply With Quote
Old December 11th, 2006, 06:11 PM   #17
Toivo
Feel lucky?
Toivo's Avatar
DIESEL
on a side note, the Power Wagons would be even more awesome with a Cummins!
Old December 11th, 2006, 10:58 PM   #18
Roadhouse
DrivewayJeeper
Roadhouse's Avatar
I can't beleive the price of plain jane Dodges now days. I went to look at a couple for work 2500, crew cab, long bed, Cummins, autos, vinyl intererior, ugly steel wheels, plastic grills, no power options, but did have a/c and criuse, both where $42k. I found plane jane Chevys, and Fords for $6k less. Dodges always where the cheaper priced vehicle of the three, doesn't seem that way anymore.
sorry kinda off topic.
Old December 12th, 2006, 05:32 AM   #19
Yetti
Yetti's Avatar
Originally Posted by XJToivo View Post
DIESEL
I know the guys who made the choices not to use the CTD in the power wagon. it was to nose heavy and wouldn't get out of its own way in the mud that is why the Hemi was the best choice. its 700lbs lighter and makes it so the axles carry the same weight when running empty. with the CTD the front axle weight is like 4200-4400 lbs depending on the model.
Yetti
Old January 19th, 2007, 02:04 AM   #20
merr6267
More boost than yours:)
merr6267's Avatar
CTD for sure. I bought one last month, albiet a hopped up 12 valve, but I don't think I'll ever have a truck with a different engine. And the Common rail engines are pretty darn easy to put get some nice hp and mileage out of with a programmer. If I was to get a new truck it'd definitely be a 6 speed auto cummins. With a Durasmack/Ally close second.
And you'll laugh at everyone with their gas motors when they go to resell them for less than half of what you get out of yours.
merr6267 is offline   Reply With Quote
Page generated in 0.29448 seconds with 84 queries
