8.8 vs. D60 clearance to ground - Great Lakes 4x4. The largest offroad forum in the Midwest
Old December 10th, 2006, 06:41 PM   #1
Noah's Ark
Noah's Ark's Avatar
Default 8.8 vs. D60 clearance to ground
Ok, trying to determine size of tire to get and need to know the difference betweent the clearance between 8.8 and d60 at the diff.
What I have found so far is that the measure from centerline of axle to bottom of diff on an 8.8 is 5 7/8" and the d60 is 6". That means only 1/8" difference. It seems like it should be more. I have only found a couple of websites that give these dimensions and am wondering if there are variations in d60 housings?
Anyone?
Noah's Ark is offline   Reply With Quote
Old December 10th, 2006, 07:05 PM   #2
Jeepaholic
Axle Guru Extraordinaire
Jeepaholic's Avatar
Not a huge difference between the different housings. You will also have to take into consideration the pinion angle on the rear will affect the ground clerance by alittle also. Most people consider a 37" tire as a minium with 60s although I have seen a few guys running 35's. My 02
Old December 11th, 2006, 05:05 AM   #3
Cooter
Dad Kickin' It OldSkool
Cooter's Avatar
The 8.8 is horrible for ground clearance- if you run one, at least shave the edge of the bottom lip so it doesn't catch on everything
Old December 11th, 2006, 05:30 AM   #4
Noah's Ark
Noah's Ark's Avatar
Actually, I am going from d30/8.8 combo to d60 fr & rr. As part of the change I do not want to lose ground clearance. I am trying to confirm that there is only a 1/4" difference. If so, I will probably just do a 37" tire and call it good. If not, then I will probably go to a 38 +.
Old December 11th, 2006, 05:42 AM   #5
fr3db3ar
KISS MY AVATAR
fr3db3ar's Avatar
I'd go with 40s if I were you :tonka:
Old December 11th, 2006, 06:45 AM   #6
PavementPounder
PavementPounder's Avatar
Just shave the D60 to make up for it or gain a little more.
Page generated in 0.20927 seconds with 41 queries
