TTB U-joints - Great Lakes 4x4. The largest offroad forum in the Midwest
Old December 9th, 2006, 03:38 PM   #1
cannaert
No more Jeep
cannaert's Avatar
Default TTB U-joints
Does the spindle need to come off to change the u- joints on it?
I have never messed with a TTB 4wd front axle the TTB OR I Beam 2wd I have done. Just wondering my Dad is getting pissed off at it and I dont have a freaking clue and how to help him.
Also how do the Axle shaft come out on that as well?
Thanks Chris
Old December 9th, 2006, 03:51 PM   #2
the frt axle joints require the brakes and spindle hub (ccenter support the rotor attachs to) to come off, the shaft will then slide through the center of the spindle
the ball joints require the spindle to be removed from the beam
Old December 9th, 2006, 04:00 PM   #3
cannaert
No more Jeep
cannaert's Avatar
i know ( DONT KNOW WHY I ASKED ABOUT BALL JOINTS) the ball joints have to have the kunchle come off the beam but we really need to know how in the Hell to get the damn Spindle off the knuckle no to pull the shafts
Old December 9th, 2006, 04:37 PM   #4
Jeeperz Creeperz
GL 4x4 Vendors
Jeeperz Creeperz's Avatar
Take off the rotors, take off the 6-nuts on the spindle and tap it loose with a soft-faced hammer (brass, plastic, wood). Then pull the shafts out.
You'll need to remove the clamp for the boot on the inner slip shaft and pull the shaft out of the boot. You can just slide it back in and reinstall the clamp (with some careful reworking of the clamp). The inner u-joint hardly ever goes bad.
Jeeperz Creeperz, Inc.
1627 Eureka Rd
Wyandotte, MI 48192
734-281-8141
M-F 10am-7pm
Sat 10am-3pm
www.jeeperz-creeperz.com
Old December 9th, 2006, 04:47 PM   #5
chris1044
chris1044's Avatar
I would advise getting the proper puller for the spindle - it threads on to it where the locks for the wheel bearings thread, and then you use a slide hammer to pull it from the knuckle. You can try the soft faced hammer method, but if it's rusted on good you'll probably end up A)never getting it off because your using a rubber/plastic hammer or B) screwing up the spindle
And the inner U-joints DO go bad....I dont see why people are so damn afraid of replacing these - they are not that hard to do, especially if you're good with a torch
Old December 9th, 2006, 10:40 PM   #6
mooseracing
Stuck like a MoFo
mooseracing's Avatar
Send a message via AIM to mooseracing
Everyone i have replaced haven't had any needles left in them. Like was stated take a torch and cut the center out. Easy and quick.
Since i have mad skills to remove the spindle i used a block a wood and big hammer and work my way around the spindle to knock it loose. Before reassembly clean the rust off the lip and coat with antiseize. Also buy a spindle bearing kit. I haven't seen one yet that the spidnle bearings weren't trashed.
mooseracing is offline   Reply With Quote
Old December 9th, 2006, 10:50 PM   #7
boggin-machine
boggin-machine's Avatar
take the 6 nuts off like said above and use a slide hammer to pull the spindle
Old December 9th, 2006, 10:51 PM   #8
88mudder
In the band!
X2
Old December 9th, 2006, 11:13 PM   #9
Buggy_Tim
(513) 891-8372
Buggy_Tim's Avatar
I don't pull anything off to do u-joints on these...well, I pull the tire off. Get a wide beam u-joint press and save time and make money.
Old December 10th, 2006, 11:09 AM   #10
cannaert
No more Jeep
cannaert's Avatar
OK Got it all apart now.
But the U-joints look like they arre welded in but i thibnk it from them never being replaced. Just do what you normale would to to get them out or do i have to heat them up at all like a chevy. Like i said i have never Messed whit this TTB set up.
Old December 10th, 2006, 01:01 PM   #11
chris1044
chris1044's Avatar
Nope, the caps should have C clips on the underside of them...between the trunion and yoke - if that makes any sense.
They're not held in by wax like GM joints.....
Old December 13th, 2006, 09:31 AM   #12
cculter
climb-on
cculter's Avatar
Go to autozone or murrays and rent the u-joint tool. Makes the job that much easier. Or use the torch method. I personally have done both.
cculter is offline   Reply With Quote
Page generated in 0.27764 seconds with 59 queries
