tooth count/gear ratio question - Great Lakes 4x4. The largest offroad forum in the Midwest
Old December 8th, 2006, 01:52 PM   #1
greenmeanie
greenmeanie's Avatar
Default tooth count/gear ratio question
does anyone know if there is a web site that tells you how many ring/pinion teeth equals whatever gear ratio? or does anyone know how to determine this? i have a lp dana 44 which i think was from a jeep. i think it is 3:55 (i turned the yoke roughly 3.5 times for one carrier turn) just want to be sure. thanks.
greenmeanie is offline   Reply With Quote
Old December 8th, 2006, 01:58 PM   #2
xj4life
xj4life's Avatar
gear tooth count/pinion tooth count = gear ratio
Old December 8th, 2006, 02:03 PM   #3
PavementPounder
PavementPounder's Avatar
Yes. These numbers will appear on the side of the ring gear, usually with a dash between them. Example: 41-10. If you can see the carrier, just rotate the yoke until you see them.
Old December 8th, 2006, 02:09 PM   #4
greenmeanie
thanks for the equation/ info
just went out and counted; 3:07's
Last edited by greenmeanie; December 8th, 2006 at 02:25 PM. Reason: calculated ratio
Page generated in 0.22091 seconds with 35 queries
