HP 44 in a Grand - Great Lakes 4x4. The largest offroad forum in the Midwest
Old December 7th, 2006, 10:31 PM   #1
Grandman
do i look old !
Grandman's Avatar
Default HP 44 in a Grand
I got this thing finished up . I took a HP 44 out of a F 250 and shortened the tubes to old bronco specs . I did this to have a common axle shaft rather then custom built parts . I set the caster at 6 degrees . I read a lot of different material and it seems there was no one setting that was highly recommended . I put a high stear set up on it to make sure i didnt have stearing issues . I was told by the those with more knowledge then I that it was the only way to get it right . Tie rod links and drag link ends are true 1 ton chevy parts , 1.25 x .25 DOM tubing was used to create the center links . Part numbers were sourced from Petersens mag , also 95geo on miss fits offered the same part numbers and pipe size needed . Thanks Bryce .
RE makes a kit that gives you the brackets to do this install but i found that pricey . While it added time to my build i did make all the brackets rather then pay the price , if you can do a little fab work and weld this will save hundreds .
Making the stearing up was not very difficult but as a whole the project was more then i had expected in money and time invested .
all work and custom parts were made in my garage other then the dual exhaust i had to install to clear the 44 center section which sits further inboard then did the D 30 .
Total cost with no labor still hit the 2,500.00 area with gears for the 8.8 and exhaust required to complete the project .
Parts list .
1 ton chevy stearing components and 1.25 x .25 DOM tubing .
KOZ off road upper stearing arm .
Alloy USA shafts , Yukon super joints
78 F 250 HP housing and 79 Bronco outers .
Mile Marker lock outs
Lock rite locker and pin .
4:88 yukon gears and carrier .
Thanks to every one that offered advice . Special thanks to H8pvnt who loaned me tools i did not have for the build .
Special thanks to Koz off road , free advice and i purchased all the components from .
Old December 7th, 2006, 11:37 PM   #2
Stan
I got a gold chain
Stan's Avatar
Congrats Marv.
Looking forward to seeing it put to the test.
Stan is offline   Reply With Quote
Old December 8th, 2006, 05:34 AM   #3
greenmeanie
greenmeanie's Avatar
looks sweet, damn sweet
greenmeanie is offline   Reply With Quote
Old December 8th, 2006, 06:11 AM   #4
PavementPounder
PavementPounder's Avatar
Flip that tie-rod.
Old December 8th, 2006, 06:34 AM   #5
greenjeep
greenjeep's Avatar
Originally Posted by PavementPounder View Post
Flip that tie-rod.
x2
any reason you didn't flip it? just curious. looks good otherwise.
greenjeep is offline   Reply With Quote
Old December 8th, 2006, 08:15 AM   #6
xj4life
xj4life's Avatar
Originally Posted by greenjeep View Post
x2
probably because thats the way the knucles are reamed from the oem. i dont know of anyone that makes flip kit yet for the large tre's. on mine i wasnt concerned with on-road durablity to i had mine machined with a 3/4" hole so i could run 3/4-3/4 heims.
Old December 8th, 2006, 09:00 AM   #7
SolLess
08' Unlimited JK "X"
Looks great. I hope to be looking like that someday too!
SolLess is offline   Reply With Quote
Old December 8th, 2006, 09:59 AM   #8
zj kid
Vern
zj kid's Avatar
Send a message via AIM to zj kid
looks real good, im starting on mine next week
zj kid is offline   Reply With Quote
Old December 8th, 2006, 10:43 AM   #9
Icebreaker88
Icebreaker88's Avatar
They make bushing's to use when you ream it from the top to flip it. That what I did.
http://completeoffroad.com/wsm/i-134...ana_44_60.html
[QUOTE=TurdBronco;1095911]I don't usually race cause it is still a focus.[/QUOTE]
Icebreaker88 is offline   Reply With Quote
Old December 8th, 2006, 10:54 AM   #10
Monkeyevil
I <3 Miatas
Monkeyevil's Avatar
x 50 billion.
But Grandman is old and grumpy and set in his ways :tonka:
Looks good.
JcrOffroad
Zoom Zoom!
Old December 8th, 2006, 12:20 PM   #11
PavementPounder
Originally Posted by monkeyevil View Post
Or pickup an already machined driver side OEM Chevy knuckle and one more high steer arm.
Is that the same spindle stud pattern as the 79 Bronco knuckles he's using?
Old December 8th, 2006, 02:44 PM   #12
Monkeyevil
I <3 Miatas
Monkeyevil's Avatar
Nope... because I suck at reading :chiefwoohaw:
JcrOffroad
Zoom Zoom!
Old December 8th, 2006, 04:06 PM   #13
Grandman
do i look old !
Grandman's Avatar
There was a reason i didnt flip the tie rods up on top . I had planned to do so but there was a lack of room . I dont know it the outers im using is a little different , the fact i used true 1 ton joints but for what ever reason there was not enough space to put it on top and have room for the Drag link to drop all the way in .
outers are off a 79 bronco front . The high stear arm was purchased from Koz , maybe its built a little differnt . I have no idea why but i wasnt able to do that . I did build an extra lower link because of it though .
Page generated in 0.47273 seconds with 62 queries
