knock sensor? to use or not on 300-6 in f-150 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old December 7th, 2006, 06:43 AM   #1
cjric
cjric's Avatar
Default knock sensor? to use or not on 300-6 in f-150
While switching everything over from the blown block to the good block (300-6) I realized that the spot on the new block (late 70 carbed) is diff than the old block (95 EFI) where the knock sensor needs to go.
A mechanic told me just leave it off and unplugged for now. It shouldn't be a problem.
Can anyone confirm this for me?
cjric is offline   Reply With Quote
Old December 8th, 2006, 11:02 AM   #2
ckupq
Kitten I'm gonna eat you!
ckupq's Avatar
Well that sounds like a shitty idea.
ckupq is offline   Reply With Quote
Old December 8th, 2006, 12:10 PM   #3
Bones
Bones's Avatar
I would defn find another port on the block and put it in somewhere. There are plenty of unused holes in the block, but they will need to be tapped to the correct size
Inviscid Motorsports
Motorcity Machines
Branik Motorsports
Maxxis Tires
Raceline Wheels
PAC Racing Springs
Joint Clutch and Gear
Old December 8th, 2006, 08:00 PM   #4
cjric
cjric's Avatar
His reasoning for leaving it off unless it poses a problem is that alot of trucks with plows or ladder racks have to have them unplugged because the rattles resonating through the truck fromthe plow or rack will trigger the knock sensor and retard the motor.
Old December 8th, 2006, 08:01 PM   #5
Nuggets
I fix stuff!
Nuggets's Avatar
Low power is better than a hole in a piston.
Old December 9th, 2006, 10:14 PM   #6
Buggy_Tim
(513) 891-8372
Buggy_Tim's Avatar
x2.
Old December 11th, 2006, 02:24 PM   #7
ScOoTeR
hoo dat. wat.
ScOoTeR's Avatar
If the sensor is unplugged, it may default into a mode with less timing to protect the engine ("octane adjust", usually 3 degrees of retard applied to the base table).
I'm saying it should be okay left off and unplugged. As fars as drilling and tapping somewhere else in the block - I would advise against it. Knock sensors are placed in the area they can get the clearest "signal" to pick up knock. Once the location is chosen in development, the knock system is tuned to ignore normal enginesounds at that location. Those will change if it is mounted elsewhere and may trigger retarded spark by falsely detecting knock.
@clarkstoncracker
Page generated in 0.22262 seconds with 44 queries
