newbie simple welding projects - Great Lakes 4x4. The largest offroad forum in the Midwest
Old December 6th, 2006, 12:45 PM   #1
jeep4banger97
Default newbie simple welding projects
i am looking for some simple projects i can do for my barn tool storage, etc that i can get some practice welding with, anything, i got the room for random crap
thanks john
jeep4banger97 is offline   Reply With Quote
Old December 6th, 2006, 12:50 PM   #2
BMFmike
meh.
BMFmike's Avatar
Old December 6th, 2006, 12:53 PM   #3
ckupq
Kitten I'm gonna eat you!
ckupq's Avatar
Originally Posted by BMFmike View Post
very nice mike. to that I top with.
Seriously though, start with simple lap butt, pipe and T welds on some plate. If you're seriously considering welding for yourself its a decent place to start.
ckupq is offline   Reply With Quote
Old December 6th, 2006, 12:59 PM   #4
BMFmike
meh.
BMFmike's Avatar
No seriously, I want it done by friday.
Old December 6th, 2006, 01:05 PM   #5
ckupq
ckupq's Avatar
what's it for?
D60?
Old December 6th, 2006, 01:10 PM   #6
BMFmike
meh.
BMFmike's Avatar
14 Bolt
Old December 6th, 2006, 01:21 PM   #7
VonDirt
VonDirt's Avatar
if youre new - new to welding forget making anything at first and just concentrate on getting good consistent - penetrating welds.
start with the simplest conditions and work your way up.
get some hunks of clean material (mild .120 or so) and go at it till you can pull off decent laps, butts, fillets, etc. while your at a bench. then start playing with thickness, go thin wall and youll be shocked how different it is. then positions, anyone whos wheeled much has enjoyed being showered in molten bbs while fixing something welding upside down. got all that covered ? move into stainless and aluminum, high carb stuff, castings - all very different acting materials even though the principle is the same. theres more but thats a start -
then again ,theres always books on the topic -
but youll catch on qiucker if you just start doing it and then go back and figure out why something works the way it does.
VonDirt is offline   Reply With Quote
Old December 6th, 2006, 02:36 PM   #8
Rocky
AAA GOLD ROCKS!!!!!
Rocky's Avatar
How thick? I might be able to help you out. The red would be the only welds.
Back on topic. Start by running some beads then once you're good at that. Do some lap, butt, t, and pipe welds. Then do them upright and lastly over head.
Old December 6th, 2006, 03:03 PM   #9
95jeepcj
95jeepcj's Avatar
lol...
95jeepcj is offline   Reply With Quote
Old December 6th, 2006, 05:10 PM   #10
Plato2k5
In Da Faaaaaace!!!
Plato2k5's Avatar
when we got our welder i just took some plate and welded different things to it like nuts, bolts, washers, other plate. Weld them different ways trying new things like circle motion, C pattern, stuff like that. Try different wire speeds and heat ranges
Old December 6th, 2006, 06:37 PM   #11
BMFmike
meh.
BMFmike's Avatar
1/2 Thick, with 2 link mounts for the top for under 200 dollars. If you can do that, blue torch fab is going out of business.
Old December 6th, 2006, 06:54 PM   #12
Strangler
Strangler's Avatar
Depends on what material you have to work with, but I would build handy garage tools that you would otherwise have to buy. Spend the retail coin on material and make your own:
Creeper,
Jack Stands,
Workbench,
Cart for your welder,
Welding table,
Engine Stand,
Cherry Picker,
Bumpers are always easy,
Wheeled carts for axles, transmissions, etc,
What welder are you working with?
Old December 6th, 2006, 07:00 PM   #13
Nuggets
I fix stuff!
Nuggets's Avatar
[QUOTE
Seriously though, start with simple lap butt, pipe and T welds on some plate. If you're seriously considering welding for yourself its a decent place to start.[/QUOTE]
Hahahaha.....you said lap butt.
Old December 7th, 2006, 10:07 AM   #14
BMFmike
meh.
BMFmike's Avatar
OK, its almost friday, progress pics?
Old December 7th, 2006, 10:28 AM   #15
xj_man_646
Wheeler-less
xj_man_646's Avatar
Send a message via AIM to xj_man_646
lol. probably still staring at the pic wondering where the hell to start...kinda like me with computer programming, i stare at the blank screen for well over an hour wondering where to begin.
xj_man_646 is offline   Reply With Quote
Old December 7th, 2006, 10:52 AM   #16
One thing no-one has mentioned here, but after you make some welds, section them with a saw, and look to see the penetration. You might want to get some dye, or alcohol with dye in it, and put it on the weld, it will highlight cracks that you can't see with the naked eye.
Thats the real key, getting a solid weld that goes all the way through where you want it to.
Doing something like getting some 1/4" thick steel, and make the same welds with different speeds, and different heat settings. That will help you learn which settings to us for which thickness of metal.
Of course, don't overlook a decent welding textbook. They do provide some decent info.
Old December 7th, 2006, 11:08 AM   #17
Stan
I got a gold chain
Stan's Avatar
Creeper,
Jack Stands,
Workbench,
Welding table,
Engine Stand,
Cherry Picker,
Those may not be the best things to make when first starting out.
Stan is offline   Reply With Quote
Old December 7th, 2006, 11:55 AM   #18
That was my thought as well...
Old December 7th, 2006, 12:16 PM   #19
Strangler
Strangler's Avatar
Sissys. Its sink or swim
Old December 7th, 2006, 07:16 PM   #20
BMFmike
meh.
BMFmike's Avatar
x2
Page generated in 0.49485 seconds with 83 queries
