What are you guys running for carbs? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old January 2nd, 2006, 01:34 PM   #1
Muttly
Muttly's Avatar
Default What are you guys running for carbs?
Got an 87 with stock carb, looking at options, anyone running the weber? hows it do off camber ect. Anyone try the 2100 on a sammy? heard it's do-able with a little die grinder work, but it seems a little big for 1300cc's.
Thanks for the help.
Muttly is offline   Reply With Quote
Old January 2nd, 2006, 08:01 PM   #2
zook94
Resident Jerkoff
zook94's Avatar
Location: Saginaw, Michigan, USA, North America, Earth, Milky way
If you are serious about getting a Weber setup, contact Sarge at Midwest performance. He is the guru when it comes to Webers. To answer your question, yep, they will work fine on off camber stuff.
Also, Toyota corolla 1.2 carbs will work, and Hyundai Pony carbs work well too. Breeze thru car-part.com to find what you need.
zook94 is offline   Reply With Quote
Old January 2nd, 2006, 08:09 PM   #3
scottie
Eye candy
scottie's Avatar
i've heard the Pony carbs are sort of crappy on angles, and very finicky.
I've been thinking about doing the Corolla Carb, but i think i'd rather just convert to Fuel Injection.
and i know aguy with a sarge weber in michigan, he seems to enjoy it, says its alot more power.
Old January 3rd, 2006, 02:12 PM   #4
Muttly
Muttly's Avatar
I noticed Sarge on izook, probably what I'll end up doing, but wanted some different opinions.
Old January 13th, 2006, 09:36 AM   #5
orionn
orionn's Avatar
Sarge-a-fyed intake, and weber, with the Sarge-Asian Auto camshaft kicks butt.
orionn is offline   Reply With Quote
Old May 16th, 2006, 01:17 PM   #6
swampjeep
Swamp Stomper
swampjeep's Avatar
how hard is it to convert to EFI?
I just bought an '87 sami with a dead motor, and a tracker 1.6 motor to drop in,
swampjeep is offline   Reply With Quote
Page generated in 0.17805 seconds with 41 queries
