CJ trail parts - nickel and dime - Great Lakes 4x4. The largest offroad forum in the Midwest
Old January 1st, 2006, 02:44 PM   #1
amc78cj7
amc78cj7's Avatar
Default CJ trail parts - nickel and dime
Clear-out sale following my rebuild. I had a very capable AMC trail Jeep with every spare part ever needed for a trail repair. Now I have no need for these parts (I am all Chevy and Ford now).
Come and get them this week only. Price is cheap, and negotiable. Make me an offer and be confident on the trail that you can get out alive.
6-bolt Jeep CJ D30 spindles GONE
2-bolt Jeep CJ D30 caliper brackets GONE
Jeep CJ Dana 30 spare shafts (widetrack) GONE
misc. castle nuts for Dana 30 GONE
Dana 30, AMC20, Dana 44 yokes with U-BOLTS (better than straps) GONE
New tie-rod end GONE
New 6-bolt Dana 30 Lockout GONE
Spring plates GONE
CV rear driveshaft for CJ with 4" lift GONE
MSD high vibration coil GONE
Ford ignition module GONE
Jeep CJ7 e-brake cable, like new. GONE
Also going cheap
15 x 8 steelies (5) - 5x5.5 bolt pattern
Jeep Dana 44 rear carrier for 3.31 gears (you get the ring gear free)
Ford Dana 60 rear standard cut carriers (2) for 4.56 and up gears
PM me if you are interested. There is all sorts of stuff that needs to leave my garage before next weekend.
amc78cj7 is offline   Reply With Quote
Old January 1st, 2006, 04:51 PM   #2
PavementPounder
PavementPounder's Avatar
I'll take all that crap. I can use the rear CV shaft right away, too. PM'd you.
Old January 1st, 2006, 05:30 PM   #3
cracker$
cheese
cracker$'s Avatar
Default Wheels
The steel wheels... What kind (black, chrome, white wagon style)?
Thanks.
cracker$ is offline   Reply With Quote
Old January 1st, 2006, 06:03 PM   #4
ovr-ez
ovr-ez's Avatar
Default 30 shafts
Are the dana 30 shafts for a wide track?
ovr-ez is offline   Reply With Quote
Old January 1st, 2006, 06:29 PM   #5
amc78cj7
amc78cj7's Avatar
Yes, 1986 widetrack D30 parts.
Wheels are steel wagon wheel, stock from a 1978 CJ7 except that they have been painted to match my Jeep (see avitar).
Old January 3rd, 2006, 03:55 PM   #6
shawn
Resident HVAC/R Jambi
shawn's Avatar
Damn SPRO!! PArts Whore! I would like the CV shaft and D44 Yokes if he don't take them.
Oh Spro, I have some shit for you still, if you want it.
Old January 3rd, 2006, 04:12 PM   #7
PavementPounder
I forgot. PM me with what it was. :tonka:
Old January 3rd, 2006, 04:45 PM   #8
amc78cj7
amc78cj7's Avatar
Shawn, I have several yokes. I can probably split a couple out for Spro and a couple for you and bring them to West Branch this weekend. Shawn, I also have that fan 304 fan shroud for you if you're still interested.
Old January 3rd, 2006, 06:39 PM   #9
PavementPounder
304 fan shroud?! Grrrr..... :miff:
I can see I'm going to have to sacrifice something here. I'll give up the yokes you need. I don't have an D44's anyway.:tonka:
Old January 3rd, 2006, 07:02 PM   #10
shawn
shawn's Avatar
Fan shroud is already spoken for
And I don't NEED the yokes, it would just be nice spares, so you can have them. I would rather to take them so you have a running Jeep then me
Old January 3rd, 2006, 07:13 PM   #11
PavementPounder
The yokes aren't really going to help me with anything since I have no D44's.
What would be helpful is someone who is a whiz at hooking up a 304 to a 258 harness...
Old January 3rd, 2006, 07:46 PM   #12
amc78cj7
amc78cj7's Avatar
I think the yokes will help both of you if I remember correctly. I checked and I have 3 that are 26 spline and one that is 28 spline. I just checked Randy's R&P and Tellico4x4 and they say the AMC20 uses a 28 spline pinion and the Dana 44 uses a 26 spline pinion. I believe the Spicer 20 t-case also uses a 26 spline yoke IIRC. At any rate, I have one for each of you.
They are the ones that use U-bolts, so you could transfer them onto your existing axle as the stronger setup, and carry your strap kind with you as a spare, or just carry spare u-bolts. I always overdo everything, so I used to carry spare yokes and u-bolts. And u-joints, and shafts and.......
Page generated in 0.19660 seconds with 59 queries
