Speedometer Recalibration for 02 ram 1500 Hemi - Great Lakes 4x4. The largest offroad forum in the Midwest
Old November 30th, 2006, 11:52 PM   #1
Mclovin
"The Situation"
Mclovin's Avatar
Default Speedometer Recalibration for 02 ram 1500 Hemi
Going from a 33 to a 35
Super lift True speed would work fine cept it claims not compatable ith the Hemi ?? Any suggestions.. if this were my truck, id prob just get used to the speedo and use the less mile accumulation my advantage...
Old November 30th, 2006, 11:57 PM   #2
PavementPounder
PavementPounder's Avatar
Yes. Just wait for the aftermarket to catch up. The Hemi has been around long enough that they should be coming soon.
Old December 1st, 2006, 11:38 PM   #3
sonic
sonic's Avatar
Youll get used to it. I never changed mine on my 01 5.9 and now I think it would be weird if it were right. Just make sure you know how far it is of at all speed ranges cause it changes. ex: Mine is 10mph off at 70 and only like 5 at 30 or so. Dont know why but thats how it is. Just not worth the money in my opinion. Plus if you ever do get pulled over you can claim that you just got the tires and "they" said it would only be off a little. Worked for me twice. now.
sonic is offline   Reply With Quote
Old December 2nd, 2006, 12:05 AM   #4
PavementPounder
Its because its a percentage that grows as your speed increases.
Old December 2nd, 2006, 12:37 PM   #5
pyrowaves
The Boss
pyrowaves's Avatar
Send a message via AIM to pyrowaves
i have a GPS that you could use to compare.. let me know..
pyrowaves is offline   Reply With Quote
Old December 2nd, 2006, 12:56 PM   #6
85 B-Duce
85 B-Duce's Avatar
There is an aftermarket spedo that uses GPS to tell you distance traveled and MPH. The only problem is that it is on the expensive side, but it is still cheaper than speeding tickets.
85 B-Duce is offline   Reply With Quote
Old December 2nd, 2006, 07:37 PM   #7
sonic
sonic's Avatar
with stock gearing you should only be about 5mph off anyways. Its really not worth the money to fix plus as I believe someone said it keeps miles off your rig. Win, Win I'de say
Old December 2nd, 2006, 08:26 PM   #8
Yetti
Buy a Fiat! Save the UAW!
Yetti's Avatar
the correct way is to re enter the tire size with a DRB. the star scan can do it also. if you don't have tire listed on the list in the scanner then you have to measure the circunfrence and figure how many times it rotates in a mile(5280 feet = 63360 inchs) so a 35" tire x TT(3.1415) = circum. in this case 109.95" divide 63360" by 109.95" and your rotations per mile come out at 576 rpm so when the scanner asks what number you want you enter that. simple Huh?
Yetti
Old December 11th, 2006, 02:41 PM   #9
dline
dline's Avatar
a dealer can adjust it for you (with a DRB)
what year is your truck???? can't be an 02.
if its an 03, you can get a Superchips programmer to change your tire size. look on ebay they should be less than $200
http://www.superchips.com/product.ph...mk=445&msg=%2B
dline is offline   Reply With Quote
Old December 23rd, 2006, 07:51 PM   #10
sonic
sonic's Avatar
He is also right about it not being an 02. The hemi didnt come in those till 03. They do make some really nice programers for those too as dline said. I know of one that you can keep updating with you PC. That may be worth it since you also will get the performance gains. Good point
Old December 30th, 2006, 10:29 PM   #11
Mclovin
"The Situation"
Mclovin's Avatar
Yep its an 03, My GF's brothers is an 02. his has a 4.7 my bad..
I think ill just go have the dealer do it.. or see if i can rent a DRB somewhere.
And after a closer inspection of my tires, its gona be a WHILE before i lay down 1000 bux for new ones..
Old February 5th, 2007, 08:55 AM   #12
Freak
Wheelin the HD
Freak's Avatar
Tiers are bloody expensive...
http://high-tec-retreading.com/DesktopDefault.aspx
I hear the retreads are good for wheeling, not so good for hot roding... going to try a set myself when I need tires...
Last edited by Freak; February 5th, 2007 at 08:18 PM. Reason: Fixing typing for PP
Old February 5th, 2007, 08:08 PM   #13
PavementPounder
Originally Posted by Freak View Post
going to try a set myself when I need tiers...
Or maybe some tires.
Page generated in 0.24149 seconds with 62 queries
