'99xj 4.0/aw4/231 D44,D60 ARB's 35's - Great Lakes 4x4. The largest offroad forum in the Midwest
Old November 30th, 2006, 10:58 AM   #1
98hd
Default '99xj 4.0/aw4/231 D44,D60 ARB's 35's
First the pics, link to the last run I took with it. http://s57.photobucket.com/albums/g2...0-22/?start=40
Selling WITHOUT the winch and roof rack that you see in the pics, roof rack is gone, and I want to keep the winch.
Asking $8,500 Jeep books at 4,700 in fair condition, about 4k in the axles.
Would possibly consider partial trade for chevy/dodge 60 front, 37-40" tires and wheels.
located in escanaba, mi (upper peninsula)
Issues:
-One front brake is dragging a little, haven't looked into it, but it seems to be an issue w/ the caliper and rotor alignment, possibly hub or spindle needed to fix.
-No e-brake cables currently
-Bright's don't work, haven't looked at it, been that way since I bought it.
-Needs an alignment
-leans to the drivers side a little in the rear, spring issue, seems only cosmetic though.
-Could use some camber shims installed to correct the camber some, which are included, last time it was aligned they said it was ok, but I didn't agree.
The rest of the specs:
1999 Jeep Cherokee classic sport 4 door 4wd 78,000 miles
Front suspension: Clayton’s long arms, and Rubicon express 7” front springs. Front axle is a ’78 ford F250 Dana 44 narrowed to around 65” and completely rebuilt. Rubicon express brackets were welded on and the C's rotated, along with a JKS relocated track bar mount. It has 5.13 gears and an ARB air locker. Sky manufacturing crossover steering arm with sky tie rod and drag link using 1 ton TRE’s. JKS trackbar narrowed to fit. Bilstein shocks.
Rear suspension: Custom concoction of springs done by the previous owner, longer shackles were added, and a 2 inch block to level, with bilstein shocks. Rear axle is an ‘80’s F250 dana 60, stock width w/ new perches. 5.13’s and an ARB also. Axle was completely rebuilt also.
Wheels are black steel procomp’s. 17x9 (yes the jeep is now an 8 lug bolt pattern). Tires are hankook MTRT03’s 35x12.5x17’s, and are pretty much new still.
The main unibody rails on the xj were sleeved using ¼” box tube cut into a c-channel shape and formed to the rails. It is bolted and plug welded to the unibody, and seam sealed along the edges. The front has had the JKS steering box reinforcing plates welded to the frame (inside and outside plates w/ sleeves for the steering box bolts). This has been done on the passenger side also. Front bumper is a protofab
ARB’s are controlled with an ARB mini compressor. There is a K&N drop in filter, TB spacer, and a Gibson exhaust that has seen better days, but is still functioning fine. Husky rear floor liner, nice thick floor mats, bar in the rear to tie down cargo. BPI rear bumper. Skid row Gas tank skid. Front brakes are the big dual piston ford calipers, rear has a disk conversion w/ elderado calipers (still need’s e-brake cables made up). Brake lines are earl’s SS braided lines all around.
Jeep performs VERY well, flexes real good (could even stand longer front shocks). A/C is cold and heat works well. Has some scrapes and dents and dings, but isn’t too bad overall. Drives down the road at speed w/o any problems, could use an alignment though
98hd is offline   Reply With Quote
Old November 30th, 2006, 12:32 PM   #2
Toivo
Feel lucky?
Toivo's Avatar
wow, words cannot express how much I want it.
Old November 30th, 2006, 12:33 PM   #3
ddeadserious
ddeadserious's Avatar
x2, srsly
ddeadserious is offline   Reply With Quote
Old November 30th, 2006, 03:24 PM   #4
trail junkie
Guest
Posts: n/a
Would a cj interest ya in trade???? Just found out this morning I need something to seat 4 and the cj is going to be cramped. I will give ya specs if interested
Old November 30th, 2006, 03:29 PM   #5
98hd
Not interested, I have another rig set to replace this one. I would keep my xj, but I could use the money for other things.
Old November 30th, 2006, 03:35 PM   #6
trail junkie
Guest
Posts: n/a
Thats what i figured, nice rig
Old November 30th, 2006, 04:01 PM   #7
xj_man_646
Wheeler-less
xj_man_646's Avatar
Send a message via AIM to xj_man_646
I'm going to PM him about the CJ instead of hijacking this thread.
xj_man_646 is offline   Reply With Quote
Old December 4th, 2006, 08:31 AM   #8
98hd
Ttt
Old December 11th, 2006, 03:06 PM   #9
98hd
Still for sale. Considering selling the axles if anyone is interested.
Old December 11th, 2006, 06:35 PM   #10
xj_man_646
Wheeler-less
xj_man_646's Avatar
how much for the axles, and do you need axles to replace these with? we could do a partial trade
Old December 11th, 2006, 06:36 PM   #11
xj_man_646
Wheeler-less
xj_man_646's Avatar
PM me if remotely interested...I am in Houghton
Page generated in 0.44638 seconds with 56 queries
