Front d44 disc brake conversion - Great Lakes 4x4. The largest offroad forum in the Midwest
Old November 29th, 2006, 11:28 PM   #1
ttocsnekia
Fawkin' Noobs
ttocsnekia's Avatar
Default Front d44 disc brake conversion
Going to swap in a hp d44 out of a 73 f100, planning on doing disc brakes. Are there any good write ups online somewhere? What do you guys suggest I do?
Thanks
Scott
ttocsnekia is offline   Reply With Quote
Old November 29th, 2006, 11:32 PM   #2
Sandals
Fucking Zen as Shit
Sandals's Avatar
Shouldn't be too hard,
I Believe (now this may be wrong)
You need Disc Brake
spindles, and backing plates.
Then you just need Rotors, caliper and pads.
But then again IIRC depending on the exact set-up you may need all new from the knuckle out
Old November 29th, 2006, 11:45 PM   #3
PavementPounder
PavementPounder's Avatar
Isn't that what you just said? I didn't understand whether you were talking about re-using the drum knuckle or not.
Old November 30th, 2006, 11:46 AM   #4
Monkeyevil
I <3 Miatas
Monkeyevil's Avatar
You will need to do some research to see if the inner "C"s are the same as a disc 44...
Then you will need everything from the knuckles out.
JcrOffroad
Zoom Zoom!
Old November 30th, 2006, 11:53 AM   #5
Sandals
Fucking Zen as Shit
Sandals's Avatar
In some cases you dont have to replace the knuckle, you can get away with just replacing the spindle that bolts on to the knuckle.
Old November 30th, 2006, 11:56 AM   #6
Monkeyevil
I <3 Miatas
Monkeyevil's Avatar
I would get these.
http://www.greatlakes4x4.com/showthread.php?t=23033
JcrOffroad
Zoom Zoom!
Old December 4th, 2006, 12:21 AM   #7
ttocsnekia
Fawkin' Noobs
ttocsnekia's Avatar
How will I know if I can reuse the knuckle? I could prolly post up some pictures
Scott
Page generated in 0.22901 seconds with 44 queries
