Air cleaner with power brakes - Great Lakes 4x4. The largest offroad forum in the Midwest
Old December 31st, 2005, 08:50 PM   #1
87'YJ
Jeeps, Journey and Jesus
87'YJ's Avatar
Default Air cleaner with power brakes
I just converted my CJ to power brakes with a YJ power brake booster. Well, the booster sticks out so far that it interferes with the air cleaner. How can I solve this problem. I wonder if I could use a YJ air cleaner setup? Any thoughts? Thanks!!
87'YJ is offline   Reply With Quote
Old December 31st, 2005, 08:54 PM   #2
Yetti
Buy a Fiat! Save the UAW!
Yetti's Avatar
I wonder if its easy to modify the filter housing? alot of times you can trim the peice out around the item and invert it and weld it back in. that or consider a TJ air filter housing and then pipe it to the right front corner
Yetti
Old December 31st, 2005, 09:59 PM   #3
ovr-ez
ovr-ez's Avatar
When I done mine I had to find a CJ air filter for P/B's. It is off set to clear the master cyl. I got mine off e-bay for 20.00. Maybe someone on here may have one??????
ovr-ez is offline   Reply With Quote
Old December 31st, 2005, 10:25 PM   #4
amc78cj7
amc78cj7's Avatar
I could look in my attic and see if I have a CJ power brake air filter and sell it for $20 if I do.
Otherwise, maybe just make your own (snorkel) setup and route it out of the way. Also, you should be able to get just about any size 5-1/4 (I think) size air filter at your local parts store. Just get a small, tall one so it fits with the booster.
amc78cj7 is offline   Reply With Quote
Old January 1st, 2006, 04:21 PM   #5
87'YJ
87'YJ's Avatar
Thanks. Let me know if you have that, I will definitely buy it.
Old January 1st, 2006, 04:45 PM   #6
PavementPounder
PavementPounder's Avatar
Yes, its just a matter of having the right breather. The offset one is the one you need.
Old January 1st, 2006, 10:35 PM   #7
clarkstoncracker
lol
clarkstoncracker's Avatar
If you end up going with the YJ air filter setup, let me know if you need the piping and the air box, I have 2 of them.
Old January 2nd, 2006, 07:11 PM   #8
amc78cj7
amc78cj7's Avatar
Mine won't work for you. It was from a 304 and I'm guessing you have a 258?
Old January 2nd, 2006, 08:06 PM   #9
ovr-ez
ovr-ez's Avatar
Default air cleaner on e-bay 5.00
I saw this one on ebay I think the bid was 5.00.
http://cgi.ebay.com/ebaymotors/JEEP-...26312257QQrdZ1
Old January 3rd, 2006, 03:51 PM   #10
shawn
Resident HVAC/R Jambi
shawn's Avatar
I just used a 6" air filter element and the appropriate hardware, got it at Murrays for like $10.
Page generated in 0.27917 seconds with 53 queries
