dual batteries - Great Lakes 4x4. The largest offroad forum in the Midwest
Old December 31st, 2005, 05:42 PM   #1
amc78cj7
amc78cj7's Avatar
Default dual batteries
Optima recommends only hooking dual batteries in parallel when they are of the same make and age.
Why is this?
What will happen if I connect a 3-year old deep cycle yellow top (that still holds full charge) to a brand new red top?
Here is what I have:
Red-top Optima, model 34/78
CCA=800
CCA @ 32F = 1000
Reserve Capacity=110
Capacity (C/20 rate)=50
Internal Resistance = 0.003 ohms
Amp hour not listed on battery top.
Yellow-top Optima, model D34/78
CCA=750
CCA @ 32F = 870
Reserve Capacity=120
Capacity (C/20 rate)=55
Internal Resistance=0.0028 ohms
Amp hour (from top of battery)=65
amc78cj7 is offline   Reply With Quote
Old December 31st, 2005, 07:07 PM   #2
Yetti
Buy a Fiat! Save the UAW!
Yetti's Avatar
DON"T DO IT!
the batteries are just different enough to draw at differnet rates. the batteries are all 12 volt but the Optima's are Gel cell and they only except a low amperage charge as compaired to a lead acid without gel the other thing I have learned about regular batteries is they are easy to cook dry. I was using a 10 amp charger and blew one to smetherines in my barn. it was an old Delco 78-a72 and it was missing the whole top when I found it the next day. luck it didn't burn the whole barn down.
Yetti
Old December 31st, 2005, 07:21 PM   #3
amc78cj7
amc78cj7's Avatar
But both mine are gel-cell Optima batteries........ How does your info apply to my setup?
Old December 31st, 2005, 07:32 PM   #4
Yetti
Yetti's Avatar
if they are both gel cells they should have the same amp hour rating and cold crank amps. if they're the same then no harm no foul, it should perform fine. what you don't want is one battery creating a draw while the other is over charged.
Yetti
Old December 31st, 2005, 08:24 PM   #5
amc78cj7
amc78cj7's Avatar
well, they are both optima gel cells; but all optimas are not created equal. They have different CCA and different amp hour ratings since one is a deep cycle. In fact, they make 2 different yellow tops with different CCA and amp hours.
If I don't run them in parallel (ie, I keep the red top for the starter and the yellow top for the winch), what would be the best way to make sure both are connected to the alternator? If they are not in parallel it would seem that the one not hooked to the alternator would be going dead fast?
Red-top, model 34/78
CCA=800
CCA @ 32F = 1000
Yellow-top model D34/78
CCA=750
CCA @ 32F = 870
Old January 1st, 2006, 05:07 PM   #6
Lothos
KD8GKB
Lothos's Avatar
Here is the problem. The charging and discharging properties of the battery are dictated by the chemical makeup of the gel/paste within the battery. Over time this rate can change quite tically depending on the conditions placed upon the battery and usage. Enough so, that if you go to use them in parralell you can quite possibly have one battery draining the other or drain one battery beyond its limits. If you wish to hookup 2 different batteries, I would not advise it without a battery management system like Painless' one.
Old January 1st, 2006, 05:32 PM   #7
amc78cj7
amc78cj7's Avatar
If I don't connect them in parallel, what is the best way to make sure both batteries are being recharged by the alternator?
Thanks Lothos. I got a similar response on POR.
Old January 1st, 2006, 06:26 PM   #8
Lothos
KD8GKB
Lothos's Avatar
Your only options are either in paralell or via a management system. Hook em up in series and you end up with 24volts and that aint pretty. You could wire them to a switch and manually switch between them every so often to keep them charged and leave one on standby. Boat stores will have a switch.
Old January 3rd, 2006, 11:47 AM   #9
KILLER"B"468
Yankabilly
KILLER"B"468's Avatar
Jeff get a boat switch or an Isoaltor, as mentioned you have 2 different batteries. So i would not run them in parrelel personally.
Old January 3rd, 2006, 03:42 PM   #10
amc78cj7
amc78cj7's Avatar
Thanks guys. I had a thread on POR also and have decided to go with the marine isolator / cab control kit from Painless. Part # 40103
http://www.jegs.com/webapp/wcs/store...tegoryId=14517
Old January 3rd, 2006, 04:31 PM   #11
Cube
Captain of my pants
Cube's Avatar
my dual yellow tops are dead
Cube is offline   Reply With Quote
Old January 3rd, 2006, 07:03 PM   #12
Yetti
Yetti's Avatar
one tip for gell cell battires is to charge them with a 250mil amp charger, they will came back to life and hold the charge longer. look at "battery tender" or one of the other rv style chargers.
Yetti
Page generated in 0.24221 seconds with 59 queries
