4.5" to 5" rear lift blocks - Great Lakes 4x4. The largest offroad forum in the Midwest
Old December 31st, 2005, 10:54 AM   #1
bikeworx
bikeworx's Avatar
Default 4.5" to 5" rear lift blocks
need to be 2.5" wide for the rear of my dodge
whatcha gots?
bikeworx is offline   Reply With Quote
Old December 31st, 2005, 01:15 PM   #2
Mclovin
"The Situation"
Mclovin's Avatar
Don't dodge trucks come with a block between the axle and leafs factory ?? if u add another 4.5-5" on top of that.. Yea that will be insane axle wrap... id look fo a set of 3/4 ton lift springs..
Old December 31st, 2005, 02:23 PM   #3
bikeworx
bikeworx's Avatar
3/4 ton springs won't work, they are 3" wide and mine are only 2.5"
Yes, dodge came with a 3" block, but after installing diesel coils in the front and a 3" AAL in the rear i am still 2-3 shy in the rear.....looks really nasty :miff:
I'm planning on 86'n the stock 3" block in favor of a taller one........i won't stack blocks, that's just insane to say the least
Old December 31st, 2005, 05:44 PM   #4
sonic
sonic's Avatar
Axle wrap is still going to a issue. I only put three inch blocks in the rear of mine to pic the back end up with the front and its just getting worse and worse as the springs get weaker. If you are going to run a block that tall you should concider either making or buying some traction bars. They will also cause your springs to wear faster.
sonic is offline   Reply With Quote
Old January 1st, 2006, 12:10 AM   #5
Mclovin
"The Situation"
Mclovin's Avatar
oh well.. I think autozone carries blocks in like 3-4" not sure about 5" but they'e preatty cheap
Old January 1st, 2006, 12:43 PM   #6
bikeworx
bikeworx's Avatar
yeah i know auto-zone has them, but was hoping i could find some thicker ones, like from a ford or something.
Axle wrap shouldn't be that bad.....had 6" blocks on my old GMC and never had a problem. Besides, i'm already thinking about the traction bars and/or ladder bars.
Might just add a couple of leafs to the pack.....might actually gain some load capacity too if i go that route
Page generated in 0.23089 seconds with 41 queries
