wont run - Great Lakes 4x4. The largest offroad forum in the Midwest
Old November 27th, 2006, 03:19 PM   #1
zj kid
Vern
zj kid's Avatar
Send a message via AIM to zj kid
Default wont run
i have a 98 ram with a 360 and i went to go start it and it ran fine, i put it in reverse and it stalled out, started again ran fine put in drive and ran fine untill it got warm, then the check engine light came on and started to stall out under 1200 rpms, code shows CPS being bad so i replaced it, then it wouldent start at all, so i cleaned the IAC started ran fine, put it in drive and ran for about 15 mins and did the same thing
what could it be
zj kid is offline   Reply With Quote
Old November 27th, 2006, 03:41 PM   #2
noodles
give 'er sh*t ay?
noodles's Avatar
I belive you mean crank sensor with cps correct? if so check for oil in the conector for the cps, if so it will short out your spark and your 5 volts to your cam sensor.
Old November 27th, 2006, 07:42 PM   #3
zj kid
Vern
zj kid's Avatar
ill check that tomorro thanks
Old December 2nd, 2006, 03:40 PM   #4
sonic
sonic's Avatar
how did it go?
sonic is offline   Reply With Quote
Old December 2nd, 2006, 04:12 PM   #5
hosejockey4506
Visiting Admin
hosejockey4506's Avatar
sounds like the cranks sensor on the back of the block
Old December 2nd, 2006, 04:45 PM   #6
zj kid
Vern
zj kid's Avatar
still the same, what els can i check
Old December 18th, 2006, 11:43 PM   #7
noodles
give 'er sh*t ay?
noodles's Avatar
does it have spark? does it crank fine? what else have ya done to it?
Page generated in 0.15910 seconds with 44 queries
